ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: lockeddiff on January 16, 2008, 05:54:41 PM
how strong are the stock axles i know they can at least handle ##s but can they hold up with some 35s?
It's all in how u drive, if you snap the clutch you could snap an axle too.
The only axle I have broken is a 22 spline front, and I was being stupid
got to bouncing under boost and pop she went
Sidekick or Sami ??? With 33's I regularly broke stock front anf rear axles. But then again I was following trucks MUCH larger than mine and pounding her hard.
How long is a piece of string?
about yea big.
i ran 33" swampers and had no problem
but i want to go to 35s
if you ran them with the upgraded calmini axels would they hold up to 35s
and its and 86 tintop sammi
(http://i148.photobucket.com/albums/s40/lockeddiff/sammi3.jpg)
its all regeared with the 6:1 calmini crawl gear
dual force clutch
heavy duty t-case mount
dual high steer system
5" lift
