ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Skunk on June 12, 2005, 04:31:28 PM
Title: Tracker Pitman arm?
Post by: Skunk on June 12, 2005, 04:31:28 PM
is there another pitman arm that fits a tracker power steering box? if so which?
Title: Re: Tracker Pitman arm?
Post by: Natebert on June 12, 2005, 04:35:26 PM
I think that Calmini, Hawk, and Sky all have aftermarket pitman arms for track/kicks
Post by: Bobzooki on June 13, 2005, 04:52:07 AM
Nate?  What're you smoking, dude?   ???
I haven't seen ANY replacement Pitman arms, but Calmini makes an Idler Arm Brace (which goes on the opposite end of the linkage from the Pitman Arm), and Sky makes a HUGE, BEEFY, MUST-HAVE Idler Arm, that replaces the stock Idler Arm.
You Can use both the Sky Idler Arm, and the Calmini Idler Arm Brace at the same time.
Post by: 1bigtracker on June 13, 2005, 06:26:06 AM
i don't know what he smoking but
http://www.puresuzuki.com/pitman_arm.htm
(http://www.puresuzuki.com/SS1583fs.jpg)
i wish he would share ;D
stu
Post by: Bobzooki on June 13, 2005, 06:40:38 AM
[url]http://www.puresuzuki.com/pitman_arm.htm[/url]
([url]http://www.puresuzuki.com/SS1583fs.jpg[/url])
stu
Umm, Stu, that's a Samurai Pitman arm, not a Tracker Pitman arm...
Post by: Zukipilot on June 13, 2005, 06:43:59 AM
Isn't that a Sami drop arm? I could not find one for a Kick/Tracker  :-/
Post by: 1bigtracker on June 13, 2005, 10:01:25 AM
opps
http://www.puresuzuki.com/kick_pitman_arm.htm
stu
Post by: Mikerpm4x4 on June 13, 2005, 01:02:29 PM
opps
[url]http://www.puresuzuki.com/kick_pitman_arm.htm[/url]
stu
Im guessing thats what he was looking for. A drop pitman for a kick box.
Mike
Post by: Natebert on June 13, 2005, 02:10:44 PM
Bob,
I'm not smoking nothing, I shouldn't be...
They all offer kick pitman arms, don't they?
Pretty sure I've seen the drop one from Calmini (thinking about ording one).
Pretty sure Hawk's got a bunch of stocky type pitman arms , plus I bet he's got the inside scooop on another make which would work too.
I'm also pretty sure Sky's got a Beefcake drop pitman arm you could order if you ask.
Maybe you should lay off hording the plumbwine and start sharing!
Post by: hcgalvin on June 13, 2005, 02:56:23 PM
Don't forget about Trail Tough too!
http://www.trailtough.com/steering_components.htm
See the last line in the top product in that list..
But maybe our original poster is wondering what kind of pick and pull pitman arms might fit a track kick..
That...
I have no idea.
Post by: Bobzooki on June 14, 2005, 01:47:49 AM
HELLO???
From The Calmini Web Page You linked to:
Arm is for the Samurai with a Sidekick power steering conversion and the factory steering system.
Why would you need a drop-pitman arm on a Kick? ???
The Trail-Tough stuff is also for a KICK STEERING BOX ON A SAMURAI.
Post by: Natebert on June 14, 2005, 03:04:50 AM
HELLO???
If you buy the 'sidekick power steering conversion' from either calmini or TT you get a kick pump and a kick box.  Then you can put a drop pitman arm on it, a drop pitman arm on a kick box....A different than stock pitman arm on a kick box.  Sound like it'd work on a Sidekick, not just a Sammy.
I'd think that everybody who's lifted their kicks more than 4 or 5 inches from the frame, should relocate their idler and pitman arm attachment points to keep their steering angles correct.  Even if you've swapped the ball joints on top, you're still at a pretty nasty angle.
Post by: Skunk on June 14, 2005, 08:27:36 AM
good info, I got the toy axles in the tracker now, hi-steer setup, 3/4" heims and 1" 1/4"wall tubing for steering, I think I may need to drop the arm a bit but damn..... $120 for an arm... wow. stock arm aint that bad..... yet.
Post by: Bobzooki on June 14, 2005, 08:57:06 AM
I dunno...
(http://img111.echo.cx/img111/4830/frontarm7km.jpg)
When you add the Calmini suspension lift, you do not change the pivot point, and you lengthen the links to the steering knuckle, to fix your toe-in, so I don't think that lowering the pitman arm, and idler arm would be a good thing...
Post by: 1bigtracker on June 14, 2005, 10:23:52 AM
HELLO???
i can think of one or two:
(http://www.granitepath.com/friends/kd7hcg/pictures/toyaxles/DCP_6510.jpg)
stu
Post by: Fity on June 14, 2005, 11:43:36 AM
If your after a cheap drop pitman arm from a wrecker, one from an early 80's Toyota Tarago van has the same spline as a power steer Vit and same shape as the 3" drop pitman arms available.  The only difference is the tapered hole is larger, so a tapered bush is needed or a larger tie rod end.  $20 cheap.   ;D
Post by: Skunk on June 14, 2005, 04:30:06 PM
hmmmm... gotta check that out..... the hole aint no big deal as I need to drill it out to 3/4" for the heim joint anyway.
Post by: Fity on June 14, 2005, 05:27:26 PM
I am pretty sure that you won't even need to drill it out as the small end of the taper is around 3/4" :)
Post by: Craw4x4PH on June 15, 2005, 06:07:28 AM
Hey Flex,
To stop the confusion these guys are giving you just go get a Sammy so you can get all the parts they're posting here ;D ;D ;D
