ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Shizamaaur on January 31, 2008, 03:34:20 PM
Hello everyone. Got my hands on a 1.6 EFI motor for cheap and im wanting to swap my 1.3L Carb. in my 87 sammy, Can I use my old harness? if not are there any good guides for wiring the new harness up? any hints? thanks everyone!
Also are there any good cams to put in the new 1.6 that would give me more power? and how easy would it be to convert the power steering from the donor to put on my sammy? thanks
i had trail tough do mine for me just plug and play.
i'm runnig the calmini adapter for the sidekick P/S
just bolted it right on with the adapter
Do you just need to send the wiring harness? also how long did it take for you to get your harness back?
you need to send the one for the FI. got mine back in ten days. every connection was labeled and easy to install . just call Brent and he'll tell you what to send .
I appreciate the help pal. ;D As for the cam any ideas?
bump
