ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: tracker8v4x4 on February 07, 2008, 04:31:57 PM
Title: tow strap
Post by: tracker8v4x4 on February 07, 2008, 04:31:57 PM
im looking for suggestions on a good strech and snap tow rope im sick of the walmart ones i broke 2 already one last night well pulling out my brothers jeep thanks for any help
Title: Re: tow strap
Post by: big_kountry21 on February 07, 2008, 05:42:11 PM
go to a semi supply store the straps they use to hold a load is what i use. fairly cheap and extremely effective.
Post by: ROSS on February 07, 2008, 06:51:38 PM
http://www.tellico4x4.com/index.php/cPath/51_993
Post by: big_kountry21 on February 07, 2008, 06:55:23 PM
yyeah thats one way to go... but i only spent like 40 bucks on a 4" 60 ft strap
Post by: tracker8v4x4 on February 07, 2008, 07:17:30 PM
how many pounds do u guys usally go with?
Post by: big_kountry21 on February 07, 2008, 07:20:45 PM
well i've had my strap through 3 rigs. a bronco w/ 8" lift and 38"s it pulled it out many times.... still pullin.
Post by: tracker8v4x4 on February 07, 2008, 07:23:46 PM
and whats the diffrance from rated and breaking strength y do they have both thanks
Post by: big_kountry21 on February 07, 2008, 07:25:15 PM
welll i don't know as far as strenght on mine... its tough as hell though. its like 80,000lbs i think
Post by: tracker8v4x4 on February 07, 2008, 07:29:20 PM
also with that high of a rateing is the sttreching worthless due to the thracke being so light
Post by: big_kountry21 on February 07, 2008, 07:30:53 PM
mine still stretches. but if your wanting to do the stretch and snatch thing use a tire.
Post by: tracker8v4x4 on February 07, 2008, 08:32:19 PM
ok thanks i just wanted to make sure if i give the truck a little yank i dont get thrown into the dash like a chain
Post by: Drone637 on February 07, 2008, 08:34:56 PM
When we go out we generally have a couple of pull straps.  The bigger rigs have the full size with loops only.  They are a much stronger end and won't rip the ends off like the tow straps with the hooks do.
I however just carry a 10,000 with hooks simply because it is much easier to use then the others.  It takes only a moment to throw on a rig, and most of the time you only need a quick tug.
I believe the rated strength of a tow rope is the amount of weight you can pull on a regular basis, where the break rating is at what point you will probably break your strap.  Remember, pulling a 2,000 lb vehicle out of a hole will sometimes take over 6,000 lbs of pull strength.   Not to mention the initial shock from when the strap first hits.
If you do a lot of "Connect up, hit throttle, bounce in the air, back up, try again" then you will probably want a rope with a bit of stretch so it can absorb the shock.  :)
Post by: big_kountry21 on February 07, 2008, 08:42:24 PM
i know its redneck but if you are wanting stretch use 2 tow straps with a tire in the middle.... no beating your face on the dash.
Post by: mrfuelish on February 07, 2008, 09:00:28 PM
Who has the extra room for hauling a tire around? I sure don't, plus I don't go out planing to get stuck but I do carry a couple of strecth type straps hooked together and they work great, the kind with the hooks my club will not allow.
Post by: big_kountry21 on February 07, 2008, 09:01:32 PM
i put it on top
Post by: big_kountry21 on February 07, 2008, 09:02:11 PM
not planning to get stuck. just prepaired
Post by: Drone637 on February 07, 2008, 11:55:42 PM
A lot of people hold this stance, mainly for safety reasons and I understand their point.  But it is always amusing on the trail when the strap with the hooks gets pulled out every time someone needs a tug just so we don't have to bother unhooking the clevis every time.  :)
If a vehicle is really stuck we usually just break out the winch rather then trying to tug them out.  If we had full size rigs I would probably take a different stance on the tow straps.
Post by: sanjuansheriff on February 08, 2008, 01:10:20 AM
While at work today my buddy got his Nissan pickup stuck.... I was able to pull him out with a 4x4 Honda quad and a tow strap.
Post by: 88Sammy on February 08, 2008, 08:21:31 AM
I get mine from Wheelers.  They support the Samurai Community.
http://www.wheelersoffroad.com/towstrap.htm
(http://www.wheelersoffroad.com/strap2.jpg)
Post by: MaD.72 on February 08, 2008, 08:41:39 AM
We use nylon cable, the same one that they use to attach fishing boat!! about a 1' thick....there though enough to pull big truck and they have good elasticity in it
Post by: big_kountry21 on February 08, 2008, 10:43:02 AM
i use to have a 3" nylon i found out at the base.... worked awesome..... got stolen
