ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: keith on October 26, 2004, 05:24:29 AM
Is there a way to soften the suspension on an 01 Tracker. It seems to bounce around more than my 90 does. Would the springs or shocks need to be softer to soften up the ride?
Did you check the tire pressure?
I have not checked. What should they be?
Look on the drivers door pillar. I'm running 23 PSI right now.
When you had it firmer what was the difference in the ride was?
More PSI = harsh ride. Zuks are very sensitive to tire air pressure.
Agreed! Pre-99 are supposed to run 23psi in the stock tires. I have 215/75/15's on mine and with 23 psi the thing wallowed around. Bumped up to 28 and it rode very stiff. Dropped it to 25 and it's perfect! ;D
Cwkick
If I air the tires below 32 on my Sammy it feels like I'm dragging a parachute behind me. So I just put up with the ride. :)
I would say a safe pressure to run your tires at is around 50psi.
i had mine at 24psi..where its been its whole life my dad hit it up to 29-30psi and i called him dumb..not only is it smother but it takes bumps better
I run the 235 75 15s at 18
and the 33s at 12
But then again, I buck the
establishment all the time
;D
My X-90 is at 28 with the street tires on it and my Kick's 33 MTR get ran at 18-20 on road and 5-8 off road.
How about adding some weight,
a winch and some extras will help
whaaat?
Sure.. and bumps go thud thud thud..
i run about 30psi in my swampers on road. seems a little rough. what would you guys(and gals ;)) say i should run?
stu
With the side wall strength of the Swamper and the weight of your vehicle. I would think somewhere around 20 psi.
stu
75psi ;D
I ran about 20 or so psi in my LTB's when they were on my sidekick.
My tires are rated D and max pressure is 65 psi for max 2335#s. I run these comfortably at 37 psi on the street. I started off at 45 psi when new and I'm still 'playing' with the pressure till I feel comfortable of the handling, control, and wear across the face of the tire. (I don't run a front sway bar.)
