ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Speedracer7c on October 19, 2004, 09:57:17 AM
Title: Best way to tension belts
Post by: Speedracer7c on October 19, 2004, 09:57:17 AM
I just had my belts off this weekend and can't for the life of me get them to stop squeaking at start up. Its driving me nuts! Anyone have any tricks to get them to quit.
Title: Re: Best way to tension belts
Post by: 1bigtracker on October 19, 2004, 10:03:56 AM
take them off. ;D :P
stu
Post by: Speedracer7c on October 19, 2004, 10:05:04 AM
THanks a-hole.
Post by: ed oorklep on October 19, 2004, 10:06:46 AM
put some sort of metal bar between the Alternator when you tighten it back down (I believe the alternator can change the tightness) and use it as a lever.... That's what I do at least.....  ;D
Post by: Mike71 on October 19, 2004, 11:03:45 AM
dont they have some sort of belt conditioner u can rub on there to stop that??
Post by: Chief on October 19, 2004, 09:38:05 PM
I used a rachet strap. Over the fender, onto the wheel. Not fender friendly, so don't do that unless you don't like your fenders!!!  :o
Post by: Zukipilot on October 19, 2004, 10:25:05 PM
A pry bar is the easiest. Snug (dont tighten all the way)the lower bolt that the Alt. pivots on, then use a pry bar to pull the belt tight and fully tighten the upper bolt to hold the tension on the belt. Then finish tightening the lower bolt. If the belt still makes noise it may need to be replaced.
Also check all the bolts that hold the brackets to the engine. I have had some of these back out before allowing the bracket to move causing it to squeek.
Post by: ed oorklep on October 19, 2004, 10:29:54 PM
That's what I ment too  ;D I'm just not as good as Zig in explaining things in enlisch (could have something to do with me not being englisch speaking)  :P
Post by: Zukipilot on October 19, 2004, 10:39:31 PM
;D At least you can get your point across, and understand other languages. I would be lost in any environment that was not english speeking :P
Post by: Speedracer7c on October 20, 2004, 12:46:42 AM
I just replaced them, and they are squeakin, thats why i'm PO
Post by: whitfield on October 20, 2004, 05:43:42 PM
You may have to remove the new belts and clean the pulleys.   Kicks and Trackers have troubles with the poor design of their serpinteine belt routing.  This is why new cars have the extra long snaking belts that wrap 180 deg+ of each pulley with idlers and spring loaded tensioners, not just the 120 deg. or so like on the Kick.    The Kicks is done off of the old V-belt design.  This is only marginally sucessful with a flat pulley.
Quote from TN Tracker off of another board on the slipping NEW belt issue:
"I had this problem myself once. Tried everything I could think of including belt dressing spray. Out of desperation I took a product called "Goof-Off" and some steel wool to the pulleys. Installed a new belt and things were quiet from then on. Seems the slipping belt had formed a glaze on the pulleys and installing a new belt without cleaning the pulleys was useless."
Goof off, Denatured Alcohol, or any other non petroleum based cleaning solvent should do the trick on cleaning the pulleys.
Post by: TomKat on October 20, 2004, 10:49:53 PM
    Wow, Ed! You're more articulate than most english speaking people I come across on various BBS's. I'm impressed.
Post by: ed oorklep on October 20, 2004, 10:53:35 PM
Thanks  ;D That could have something to do with me being on zukiworld all day long  ;D
Post by: r0ckstarr79 on October 21, 2004, 02:12:32 AM
stu
No no, he needs some WD-40 ;D
Post by: wildgoody on October 21, 2004, 03:32:07 PM
When one of the pivot bolts falls
out of my alternator, I get a squeal,
so check for 2 bolts on the bottom,
1 front and one rear
Post by: Speedracer7c on October 21, 2004, 03:33:59 PM
I'll check it out tomorrow, clean the pulleys and what not, I'm sure they are glazed over.
