ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: kubik1981 on April 24, 2008, 06:30:48 PM
Title: 1990 tracker 8v 5sp supension ?
Post by: kubik1981 on April 24, 2008, 06:30:48 PM
what kinda springs can i put in my truck that will lift it a little but not make me have to move anything like shifters or brake lines
Title: Re: 1990 tracker 8v 5sp supension ?
Post by: Element on April 24, 2008, 09:25:24 PM
are you interested in a budget lift using coil spacers or do you want to use taller springs? The budget lifts are way inexpensive and some of the coils suspensions can get pricey... There will be a difference in ride quality... This is where you ask yourself... Is the little bit of ride and performance worth the extra $$$$???
Here are some links that can be found in the Archive section of this site:
http://www.zukiworld.com/month_050107/feature_budget-4doorbuild.htm
http://www.zukiworld.com/month_120104/feature_calmini_2inch_install.htm
http://www.zukiworld.com/month_120104/feature_sky_bodylift_install.htm
Jerry!!!
Post by: karl214 on April 24, 2008, 09:42:50 PM
I just threw in a set of one inch spacers in my daily driver, already had longer shocks on it... I can see that even with one inch spacers that it sits higher...
Post by: Element on April 24, 2008, 09:48:58 PM
Karl, it starts with a 1" inch spacer.... ::)
