ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: serioushorsepower on May 06, 2008, 02:11:55 PM
Title: Need help with P.O.S. starter!! Please??
Post by: serioushorsepower on May 06, 2008, 02:11:55 PM
Everytime I take my trackick off road mudding the darn solinoid goes in the starter. I'm on I think, My fifth one by now. Does anyone know what other vehicle starter would interchange with the trackick starter? Or a possible solution to fix the problem I am currently having? It's getting quite expensive to go offroading at this rate. Please let me know. Thanks, Serious.
Title: Re: Need help with P.O.S. starter!! Please??
Post by: kingzoo on May 06, 2008, 04:19:46 PM
  Do you have problems any other time when using the Zuki?If so I would check for a short,bad relay,or possibly starter.
  If not I would try to dertimine which driving conditions are causing the problem.Water.mud,etc.
Post by: serioushorsepower on May 06, 2008, 04:27:21 PM
I have no other problems with it until I take it off road. I think it's the mud and water doing it. Is there any way around this problem with these? Possibly a better starter or one from a different vehicle altogether?
Post by: Rhinoman on May 07, 2008, 05:16:54 AM
You should be able clean out the starter, they don't usually get damaged just blocked up. Try sealing up the bellhousing to stop the mud getting in.
Post by: Dazookster on May 07, 2008, 03:34:05 PM
First mud is the hardest on every thing on your rig, bearings, fluids, electrical, cooling, horns (mine was filled with mud from the previous owner).  So I would start by water/dust/mud proofing that area and seeing if that doesn't fix the problem.
