ZUKIWORLD Model Specific Suzuki Forum => Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005 => Topic started by: toofaroffroad on May 21, 2008, 09:08:22 AM
Has anyone ordered from Boondox recently? I've emailed twice and called but no reply. Just curious, thanks for any help.
I wait for my struts extentions since January... >:(
OK thanks, I guess that answers my question. I'm also looking for strut extensions.
I ordered a set a this year. It was a little wait. Now if I could only use them! Tryed installing/ trimming/ sanding and its not happening. Lots of people have successfully uinstalled them though!
Anybody had any luck hearing back from Steve |removethispart|@ boondox yet?
I'm looking for some pieces for my brothers new rig.
I've emailed twice and even called his phone and no reply since early May.
FOr you guys that are looking for a set of strut extentions, www.roadlessgear.com sells them. I just purchased a set from them. 45 bucks.
Where did tou saw the strut ext. on roadless gear.
there's nothin g in suspention .
Marc ???
I carry them instock and could supply for $65 Us to your door.
Outdoor Auto
$45 dollars is a very good price for a set of strut extenders. I bought two sets from Boondox back in about November of last year. As I have stated in earlier threads, they wouldn't screw down over the shoulder of the struts and i used an air dremmel to gain the needed clearance on the strut shafts so they would fit.
On my second set, I took them over to my neighbor's tool shop along with another new Monroe strut. He mic'd the shaft thickness at .666, then he mic'd the internal width of the strut extender and found it was .002 under the strut clearance required. He placed both of my strut extenders in his lathe and cut away the needed clearance. He noted the inside of the strut extenders were out of round (= he didn't have to take metal off of all the inside... just "high points"). By the way, they were made of standard "soft" steel. he cleanranced my strut exteneders for free, bless his heart.
Now the strut extenders screw onto the struts very cleanly and snugly. In fact, the oil I placed on the shaft caused a vapor lock when i tried to unscrew them.
I asked him how much it would cost to fab a set of these. He estimated (in his head, he didn't run a calculator on the costs) that fabbing a pair of these would run about $300 or $150 each. That's making them out of a little stiffer quality steel also.
He estimated to bring the costs down on these to around $50 a pair he would have to work an order in the area of about 100 pair of extenders. He's a small shop, but he's been "in the business" for about 20 years and I take his knowledge and experience as pretty accurate.
So apparently these extenders are being jobbed out to chinese manufactures (my guess) which explains the quality (or lack there of) and also the difficulty in obtaining them when your on hand stock runs out as apparently has happened to several dealers.
Norm
I know you guys are using strut extenders, but I make strut spacers from polyurethane that works just as well. I'm selling them with cap screws and lock nuts for $40 a pair to US and $45 to Canada. Just thought I'd throw that out there.
need to fit Grand vitara's not vitara's, i also supply vitara strut spacers but they are different to GVs
Good to know. I did not pay attention to the thread title. :sleepy:
Hi All
I also import from asia and i have had no trouble with them fitting
(http://i129.photobucket.com/albums/p213/fordy1zuk/Outdoor%20auto%20products/reImage034.jpg)
you can see in the pic that one is on a OME strut shaft and it was no trouble
like i have said if anybody is after them i can supply for $65 Us to your door just email me
Tim
OutdoorAuto4x4
http://stores.ebay.com.au/Outdoor-Auto
Huh?? What's the difference, exactly? I can see pre-1999 Track-Kick stuff being incompatible with 1999-2003(5) Track-Vits, but I'm not aware of any compatibility issues with anything in front of the firewall between 1999-2003(5) Trackers, Vitaras, Grand Vitaras or XL-7s, regardless of wheelbase.
Are you confusing European/Australian branding terminology with US branding terminology, or are you saying a 2003 GV (long-wheelbase) strut has an entirely different top than a 2003 Track-Vit (short-wheelbase) strut?
He's in Australia where most of the pre-99 vehicles were referred to as Vitaras. jeff makes parts for the older style with the different strut mount setup.
yep, anything here after 98 is a GV
vitara is this shape
(http://i129.photobucket.com/albums/p213/fordy1zuk/dscf4092-border.jpg)
with this strut bracket
(http://i129.photobucket.com/albums/p213/fordy1zuk/IMGP1329.jpg)
and GVs
(http://i129.photobucket.com/albums/p213/fordy1zuk/IMGP1531.jpg)
and the strut spacers are
(http://i129.photobucket.com/albums/p213/fordy1zuk/reImage034.jpg)
