ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: IrishMike on May 27, 2008, 12:56:01 PM
Title: Anyone know if these wheels will fit a 96 Tracker 4WD?
Post by: IrishMike on May 27, 2008, 12:56:01 PM
http://store.summitracing.com/partdetail.asp?autofilter=1&part=AEW%2D0289%2D5055&N=700+400077+303171+115&autoview=sku
Looking to purchase some new wheels and like these... Wondering if they will fit my 96 Tracker.
Title: Re: Anyone know if these wheels will fit a 96 Tracker 4WD?
Post by: Rhinoman on May 27, 2008, 01:03:34 PM
It doesn't look like you'll be able to fit the caps on the front wheels if you have freewheel hubs
Post by: phloop on May 27, 2008, 02:55:42 PM
You should be able to get caps to fit the front hubs.
Post by: Drone637 on May 28, 2008, 03:22:45 AM
Kind of wide at 10" though.  I run 8" with 33x12.5" tires and can't really see going with a wider wheel unless I was bumping up to a 14.5" wide tire.
Post by: MUD CHILD on May 28, 2008, 04:03:21 AM
They are the right bolt pattern, but 10" is a little wide, a 7" or 8" rim would be better
Post by: ack on May 28, 2008, 06:49:54 PM
The description does not indicate the size of the center hub hole.
The hub hole size - not the bolt pattern - is what makes a lot of wheels unusuable for Samurais and Sidekick/Trackers.
Post by: Jookycola on May 29, 2008, 07:47:51 AM
I had those wheels on my Samurai back in the day.  They fit...or at least they made some that cleared the hubs.  When i had mine the rim shop ordered them with special center caps that had a hole in them so the hub lock could poke through.  So i know they at least used to fit and had special covers for 4WD vehicles.
