ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: OHIO_ZUKI on June 09, 2008, 09:25:51 PM
Title: When swapping ring and pinion...
Post by: OHIO_ZUKI on June 09, 2008, 09:25:51 PM
I am considering swapping my 4.625's for a set of 5.12's. When/if I do this, are those the only items that I need to replace? Will the current, sleeves and bearing things work, or do I need everything from where the 5.12's came from?
Title: Re: When swapping ring and pinion...
Post by: Carnage on June 09, 2008, 09:42:38 PM
dude, we've already asked you once to post in the right section
Post by: OHIO_ZUKI on June 10, 2008, 05:34:42 PM
Well is this not the Do It Yourself forum??? What forum should I post this is???
Post by: Amilla on June 10, 2008, 06:24:24 PM
I think they want you to put it in the "Suzuki Forum" section.
This section is for people that are building up there rigs, and for people showing how to make snorkels, and other things that can be done from your garage.
Amilla
Post by: rascott on June 10, 2008, 07:07:53 PM
ohio-zuki
diy is a little misleading, huh.
it's clearer to me now- thanks amilla
richard
Post by: Carnage on June 10, 2008, 09:44:25 PM
Amilla
that pretty much sums it up right there
as you posted a general "repair"
now if you did the gear swap and documented it with pictures and instructions
the How-To/DIY section is the place to be
Post by: ZeusZuki on August 05, 2008, 09:26:25 PM
http://www.zukiworld.com/forum/index.php?topic=21156.0
Look in here, might help you.
And yeah, wrong place dude  ;)
Post by: phloop on August 06, 2008, 11:26:14 PM
Don't worry about it OHIO_ZUKI , this place is a little confused itself. No A&E, no tech, no seperation of the generations so you kinda have to guess where to post your question.
Don't let these guys drag you down.
Post by: bzzr2 on August 07, 2008, 12:30:20 PM
why is this the wrong section?
Post by: Drone637 on August 07, 2008, 04:27:13 PM
This is the right section.  Before it was in the Do It Yourself section, which is for project write-ups.
Post by: Skyhiranger on August 07, 2008, 06:57:08 PM
Just get complete thirds and swap them.  Much easier than swapping and setting up gears.
But if you want to swap and set up gears......yes, the bearings and crush sleeve is the same in the 5.12 and 4.62 thirds.  The only difference in 89-98 trackick 4.62 and 5.12 thirds is in 96 the front started using 26 spline axles and sidegears.
