ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: bhmudder11 on June 10, 2008, 05:04:47 PM
will the manual for a 1988 work for my 1987 samurai.
and when it states to use 75w90 oil can you 80w90 with no effects. i live in texas so it gets really hot here and it is hard to find 75w90 oil
Yes and yes.
thanks alot. and it takes 1qt?
Depends what "it" is. The tranny, axles, and tcase all use gear oil. But on any of them you put enough oil in until it runs out the fill hole. Your manual should tell you the capacity on each thing.
srry the 1qt message was not supposed to be posted thanks anyways
There are slight differences in the 88 and the 88.5 Sami's, some styling diff's, larger D-shaft flanges and a differently plumbed brake system, and a different 5th gear ratio are the only thing's that are different.
