ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: lokomonkey on October 05, 2004, 06:30:46 AM
I need to know "whats the point on having an 'anti sway' bar install, the one from Calmini. does it really affects your driving? how?
sorry I forgot!! install in a '90 sidekick
You will get less lean in high speed cornering on road, but less flex off road.
I had a set and they made my Tracker very stable and would corner very flat, but it killed my flex off road. If you mostly drive on the street or have a lifted Trak/Kick that leans a lot in corners I would recommend them. Otherwise, spend your money on something else.
Cwkick
I built a remote swaybar disconnect in my tracker and I can definitely tell the difference on the road. I like the results but not the operation. I am redesigning the disconnect and will post when I get one that works better.
I think most of us will be interested in seeing how that turns out.
Speaking of...
anybody seen any place other than calmini or p.s.t that has performance sway bars for a sammy?
we used a sammy sway bar for the kick when we did this SAS setup, and it'd be cool if I could get one that's high performance, with poly bushings, to help me out on the road.
Speaking of...
check out calmini's sway bars for the sami
Speaking of...
Why not look for the Currie Rock bar? It's just a simple torsion bar contected with long swing arms which are then attached to the axle. Lifted coiled Jeeps run these continuously, even off-road. Some of the rock crawlers run them during competition.
