ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: offlimits4wd on June 24, 2008, 04:11:37 PM
One of the must does before the next comp is get some better rear brakes. I'm thinking about rear disc and have done research on what I will need but am wondering about master cylinder upgrades. What works best. (Oh I forgot 92 Tracker with stock master w/ Toyota axles)
I'm mostly in need of better cutting brakes. Right now I have to mash the handbrake really hard to get them to work.
To sum it up I want to be able to hit the hand break with ease, lock either side tight with ease so I can get the most out of the front dig.
Thanks Bryan
Your running Toyota axles, so your going to probably want to hit Pirate or a Toyota forum for brake info on a disk brake conversion.
For cutting brakes there are a couple ways to go. One is with a line lock for each tire, or just each rear. That way you can lock one rear tire up and spin around it. However, if you have a rear locker and not a selectable (arb, ect) then this isn't going to help much.
To upgrade your master cylinder I was looking around and found a post on a Canadian board that mentioned that both a 92 Civic Booster and Jeep Wagoneer booster will swap in. But the Wagoneer requires a swap to standard flares for your brake line. Might be a good read for you. Link to Thread. (http://www.zookpower.ca/forums/showthread.php?t=1917)
