ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: eschneider on July 13, 2008, 10:14:14 PM
Title: '92 TRACKER HEAD WARP SPECS
Post by: eschneider on July 13, 2008, 10:14:14 PM
Have a '92 TBI 8V tracker.  Got hot, water in the oil, pulled the head.
With 2 different straight edges, measured 0.010 warp in the center (cylinders 2-3), 0.008 between 1-2 and 3-4.
What's the spec?  Anyone know how much warpage these motors can take?
I ask because the car has 200k miles, and I'm not planning on checking the main bearings other than an oil pressure test....  Just doing a $40 gasket.
Title: Re: '92 TRACKER HEAD WARP SPECS
Post by: wildgoody on July 14, 2008, 07:44:32 PM
I would have it surfaced, just take 8 thou off, and if you do a valve job, you
will need a new set of rings in 20-30K miles
Good Luck
Post by: eschneider on July 14, 2008, 08:19:49 PM
Thanks.  I think I will follow your advice.
Any reason to just take 8 off, and not 10 thou??
It sounds like you're saying there is a cause-and-effect with a valve job and rings?  What's that all about?
Post by: wildgoody on July 17, 2008, 05:56:04 PM
Increased compression in an engine with that many miles will wear the rings out.
This is a common problem with all engines, they don't like to be messed with after
they are broken in.
Taking more off will increase the compression, tho not much, but 2 thou warp is in specs
and will give you more service life in that head should you ever need to resurface again
Post by: eschneider on August 12, 2008, 05:04:31 AM
since I'm not sure about the bearings, and the motor has 200k miles on it, I decided to try using a long flat file (and some machinist's blueing paint) to very carefully dress the head surface.  If nothing else it will be one of those experiments to see what I can get away with.  With the file I got the surface flat to about 3-4 thou.
I'll let everyone know how this works.  From a practical standpoint, I'm insane for trying -- but it's a fun experiment that I couldn't resist.
Title: Re: '92 TRACKER HEAD WARP FIX
Post by: eschneider on August 29, 2008, 11:09:56 PM
Posting the follow up to my experiment.
To review, the motor got hot, blew a head gasket.  I had just done the head gasket last summer, but my dad's been driving the car with a cracked radiator..... ugh.
Last time I did the job I replaced everything - timing belt, hoses, gaskets, even a new timing belt cover.
This time, I replaced ONLY the head gakset.  I pulled the head with the intake and exhaust still bolted on.  however, the head was warped about 10 thou.
I decided to try a cheapskate experiment.  I used machinists bluing dye and a 18" flat file to dress the head surface.  I got it to within .004" flat and left it there.  I bolted it on, and everything is OK so far after about 300 miles!!!!!!!  I even re-used the valve cover gasket - I just coated the gasket surface with standard grease to help it seal, and so far so good.....  Compression is back up to 145+/-10 psi.  Pretty good for an engine with 200k miles.  What a great, durable motor.....
Total spent = $35 for the head gasket, plus consumables (cleaner, oil, filter, antifreeze.....)
