ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: ppltrak on August 20, 2008, 10:59:43 AM
Title: Broken moter mounts
Post by: ppltrak on August 20, 2008, 10:59:43 AM
I keep breaking moror mounts on my kick. 8v eng 94 year has anybody else had this prob. If I wheel hard they only last 1 trip.
   Kevin
Title: Re: Broken moter mounts
Post by: ROSS on August 20, 2008, 01:02:55 PM
I've seen you drive :P :P :P
I run the heavy duty ones from TT
Post by: 86badboy on August 20, 2008, 05:48:49 PM
teh full circle mounts are supposed to be awesome.  they also use spring bushings so they are cheap to build.
Post by: ppltrak on August 21, 2008, 07:46:10 AM
Who makes the full circle mounts? Will they work on a Kick?
   Kevin
Post by: ROSS on August 21, 2008, 08:39:20 AM
petroworks does for the sammi conv.  .  call and see about the kick
http://www.petroworks.com/drivetrain-accessories.php
Post by: rascott on August 21, 2008, 10:58:34 AM
i understand some people are using 318 dodge pickup mounts.
Post by: ppltrak on August 22, 2008, 01:50:26 PM
My problem right now is that the oil pan is too close to the steering drag link. Something is not right.
    Kevin
Post by: ppltrak on August 25, 2008, 07:49:14 AM
Has anybody used the HD motormounts?
    Kevin
   Ps the dodge 318 mounts are only 1.5" wide and the stock mounts are 2.5"
Post by: ROSS on August 25, 2008, 07:57:21 AM
i've been running them for several years now. haven't broke one yet.  knock on wood
Post by: safarikick on August 25, 2008, 07:08:09 PM
can you use the dodge motor mounts i a kick with a 16v
Post by: 86badboy on August 25, 2008, 07:53:55 PM
anything is possible with a lil cut and weld... :P
Post by: blackandtan on August 26, 2008, 05:05:14 PM
You can also fill the stock mounts with 3m window weld, its a very strong urethane that bonds to rubber well, it tries to a rubber like consistency. works great for stiffening up motor mounts, have used it on most of my vehicles for years.
Post by: ppltrak on August 26, 2008, 05:25:19 PM
I tried to order some HD motor mounts from Low range but he called his supplier and they don't make any for 92 and later kicks. So whats the deal, is a heavy duty motor mount not available? I guess I'll just have to fab up some full circle mounts. I do have some rear control arm bushings but I think that I'll get some bad vibes if I use them.
   Kevin
