ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Rileysowner on September 08, 2008, 06:51:32 PM
Title: ECM Question
Post by: Rileysowner on September 08, 2008, 06:51:32 PM
I have a '93 Sunrunner and am looking at a '94 tracker that won't run and may have a bad computer.  I am not too worried if it won't run because my '93 does.  My question is there any difference in the ECM from the '93 to the '94 and could I swap the '93 to see if the ECM is the problem and maybe get it running so I can get it home?
Title: Re: ECM Question
Post by: wheresmyhat on September 08, 2008, 10:57:29 PM
shouldn't be a problem as long as they are the same engine.
Post by: Rileysowner on September 09, 2008, 05:57:01 AM
Both are two door convertibles and I believe both have 8V engines.
Post by: Rhinoman on September 10, 2008, 04:50:53 AM
Take a look inside, if the boards look the same then it should run. There are something like 70 ECU variants across the Track/Kick model range. Most are minor software variations.
Post by: Rileysowner on September 10, 2008, 06:29:15 AM
Thanks everyone.  Sadly, and I mean really sadly, I missed out on this one as someone else grabbed it before I even received a response from the seller.  I will just have to keep my eyes open for another in the area.
