ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: brace on September 24, 2004, 02:40:20 AM
Title: blowing white smoke
Post by: brace on September 24, 2004, 02:40:20 AM
I just swapped my intake manifold and carb for a new set because it was runnng rough.   And now white smoke (burinng coolant is what my mechanic calls it) is coming out like crazy.  It's running great but smoke is pouring out.  Any suggestions?
Title: Re: blowing white smoke
Post by: wildgoody on September 24, 2004, 03:11:08 AM
Use a new intake gasket, and replace
it, also use some Permatex Copper Spray
gasket sealer, it looks like copper spray paint
Expensive, like $6 a can, but works well
Unless you have a problem with the new
manifold where there is a breech in the
coolant passage, then you need to swap parts
Post by: steveofrost on September 24, 2004, 03:56:20 AM
Heh, blowing white smoke... for a moment there I thought this was a Water Cooler post... ;D
steveo
Post by: JDraper on September 24, 2004, 11:49:03 AM
Yep, new intake manifold gasket would be my guess.
Post by: explosivo on September 24, 2004, 11:52:23 AM
I forgot to put a bolt on my manifold once, and it blew white smoke when it got up to temp.
Post by: bandit86 on September 24, 2004, 01:45:42 PM
cracked the aluminum head by overtightening a bolt
Post by: 1bigtracker on September 24, 2004, 02:21:18 PM
head gasket rotted out of mine
stu
Post by: Mike71 on September 24, 2004, 02:22:28 PM
that can happen but from what my dad tells me ( a wrencher for life lol) it is mainly when the engine is hot.i can happen when its cold but *normally* common sense kicks in before u have cracked it
