ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Low Range on September 25, 2008, 11:52:13 AM
Title: In need of Samurai Tcase cores
Post by: Low Range on September 25, 2008, 11:52:13 AM
We are in need of case cores again.
We offer $200 instore credit for fully usable cores and less as quality diminishes.
We are at the moment reusing all parts of the cases except the old bearings and some of the gears. In the near future we may need original gears and shifter as well though so keep what you have.
If you have any questions please call or email me at sales|removethispart|@lowrangeoffroad.com or 801-805-6644
Sean
Title: Re: In need of Samurai Tcase cores
Post by: hawaiizuki13 on September 25, 2008, 12:33:58 PM
i might have an extra one the thing is i live in hawaii i can see what i can do but yeah i got a ? with would be a nice gear set for 31's only need the rear cause im hardly going to 4 wheel it lmk thanks
Post by: Amilla on September 25, 2008, 06:52:00 PM
If your talking about a gear set for your transfer case, for 31s i would go with a 4.9:1 gear set.  If you want to rear gear your ring and pinion you would have to gear both front and rear.  You would run into binding issues and not be able to use 4wd at all.
Amilla
Post by: hawaiizuki13 on September 25, 2008, 07:02:29 PM
what gears would be better t gears or thirds??? dont want to spend that much would be more on the road then off road
Post by: bashzuk on September 27, 2008, 05:34:07 PM
you are going to spend less with the t-case gears than axles gears
Post by: 1badzuk2 on September 28, 2008, 10:42:26 PM
i have a t case with bad beaings in great shape other then that you want it pm me
