ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: mike5721947 on September 25, 2008, 09:42:46 PM
Title: winchs?
Post by: mike5721947 on September 25, 2008, 09:42:46 PM
ok, got the kick stuck in a bog the other day, 3 hours later, it was back on its way...
gotta get a winch on the truck before going back out, i dont wheel with other trucks most of the time so its me only to get me out. (well, the girlfriend too... ;))
http://www.superwinch.com/GP3000_3_000_lbs_615.html
canadian tire has them for $130, my only question is are they reliable and is 3000lbs enough... (had the truck up to the doors in the bog... (doors wouldnt open....) made it interesting having the girlfriend get in and drive while i pushed, jacked, dug, and pulled...)
Title: Re: winchs?
Post by: bzzr2 on September 26, 2008, 06:46:35 AM
i wouldn't count on that little winch getting you out, that's a 4wheeler wich most likely..  i believe the recommended minimum is 1.5 times the vehicle weight.  it may help but when you're bogged down like that there's a lot more than the vehicle weight that the winch has to content with.  i saw a tracker with a 3000 pounder in some mud, was the 2nd time they used it and it died never to come back to life.  i've seen guys with 8000's have to snatch block cause they were stuck so bad.  look for at least 4000lbs+ and get a snatch block and some extra rope/cables.  personally i have an industrial come along that has worked better then small winches in some situations.
Title: Re: winchs?
Post by: locjaw on September 26, 2008, 07:20:23 AM
if your gonna try to suck your self out of the mud, i'd go even larger. if your not gonna use it a bunch i'd just go with the harbor freight 8000#. you can find it on sale once a while for $250
Title: Re: winchs?
Post by: Amilla on September 26, 2008, 09:54:54 AM
I have heard pretty good things about Smitty built winches.  They can take a beating and dont like to quit.  They also have a price that wont make you cringe
http://www.winchdepot.com/PDT430788.aspx
If you were to run an 8000lb winch i don't think you would have a prob getting out of some sticky situations.  My buddy is running a harbor freight 5000lb winch on his 4dr kick.  He got buried up to his frame and that little winch would not do it!
Amilla
Title: Re: winchs?
Post by: mike5721947 on September 26, 2008, 05:06:22 PM
would a 6000-8000lb winch sag my front suspension?
Title: Re: winchs?
Post by: Drone637 on September 26, 2008, 05:31:39 PM
Probably a little bit, especially with a new bumper.  A set of 1" coil spacers from Jeff1997 or some springs from a 4 door (if you have a 2 door) should take care of it.
Title: Re: winchs?
Post by: Amilla on September 27, 2008, 09:50:02 AM
You could always cut down the weight by running some synthetic line.
Its a lot easier to work with also.
Amilla
Title: Re: winchs?
Post by: Uncivilized on September 27, 2008, 02:32:58 PM
[url]http://www.superwinch.com/GP3000_3_000_lbs_615.html[/url]
Princess Auto often runs a special for the Superwinch 8000LB, $449. That would be your best buy. Also look for used ones in your area. You really want 6000LB - 8000LB, and you'll need to make a bumper, or a heavy duty mount that is securely mounted to the frame. A good deep cycle battery is also good to have for a high draw item like a winch.
Title: Re: winchs?
Post by: rockrat on September 28, 2008, 08:57:56 AM
I have 8000# warns for $695. right now while they last
Title: Re: winchs?
Post by: RHodge on September 28, 2008, 11:34:21 AM
Amilla
I was moving my winch around with the cable off and couldn't believe how light it was.
Title: Re: winchs?
Post by: bentparts on September 28, 2008, 02:24:32 PM
[/quote]  No doubt, a hundred feet of steel cable is heavy, but have you priced synthetic line? Whew! I'm still looking to convert, but only when I can find a deal.
Title: Re: winchs?
Post by: 1badzuk2 on September 28, 2008, 10:47:48 PM
i have a 9000lb mile marker only paid 299 new and it works fine i keep it in the back and only put i on when i need it pulled a full size chevy truck out of the mud
Title: Re: winchs?
Post by: Digger on September 29, 2008, 11:55:48 AM
Back when I had my 90 Tracker, I used a 3000# Milemarker and it never failed to pull me or my buddies out. If I had to do it again, I would have gotten at lest a 6000#. I think you can get away with a 3000# if you stick to a name brand like Warn, Milemarker, etc, but if you are buying a less well-known name, you would want something bigger. Also if you do go with a 3000#, make sure to use a snatch block...
Title: Re: winchs?
Post by: Uncivilized on October 07, 2008, 03:09:27 PM
[/quote]How much are you looking to pay? I can get Amsteel Blue pretty cheap.
Title: Re: winchs?
Post by: mike5721947 on October 07, 2008, 05:13:18 PM
all the shops around here only go with warn.
m8000- 800
m6000-700
tabor 9000-800
and a calmini front bumper at 777.60 plus tax.
all the other winch bumpers from zukination, shrockworks, etc are around 800.
zukination is probably what I'm going to go with just for supporting a local company (30 mins down the road) i love the shrockworks one and would love to see a matching rear but its so far behind i cant wait much longer...
eitherway i want to go with a ZOR rear bumper when they come out (as long as the hitch part is DOT approved (want to seriously tow reliably with it)
Title: Re: winchs?
Post by: ROSS on October 07, 2008, 07:20:47 PM
the most I see is less than 600.00
http://www.puresuzuki.com/winch_bumper.htm
Title: Re: winchs?
Post by: mike5721947 on October 07, 2008, 07:47:48 PM
ya... $777 to calgary. shipping sucks to canada....
Title: Re: winchs?
Post by: ROSS on October 07, 2008, 07:51:41 PM
drive to the states , get the bumper, and bolt it on , then drive home.
problem solved
Title: Re: winchs?
Post by: Armour on October 07, 2008, 09:28:33 PM
I have a Warn M8000 on mine and have no complaints with it!
Title: Re: winchs?
Post by: Rod on October 08, 2008, 12:41:36 PM
4-Wheel Parts has the Warn m8000 for $569.
It's a solid dependable winch.
http://www.4wheelparts.com/Winches-Winch-Accessories/M8000-Self-Recovery-Winch.aspx?t_c=18&t_s=300&t_pt=100702&t_pl=6407&t_pn=WAR26502
Rod
Title: Re: winchs?
Post by: bentparts on October 09, 2008, 04:51:31 PM
[/quote] What would 100 ft cost? I have a warn 6000.
Title: Re: winchs?
Post by: mike5721947 on October 09, 2008, 06:57:28 PM
well... picking up a ZOR front bumper for WAY cheaper then the rest even with the shipping... cant wait to get it...
would love to throw some amsteel on a winch... lot nicer and safer...
Title: Re: winchs?
Post by: Uncivilized on October 30, 2008, 04:15:59 PM
PM Sent.
Title: Re: winchs?
Post by: mike5721947 on October 31, 2008, 05:01:46 AM
hows the superwinch 8500lb model? can tire has it on special for $399 this weekend. (m6000 was 800 here, so was tabor 9000)
I GOT MY BUMPER!!! now to find a place to powdercoat it.
Title: Re: winchs?
Post by: Drone637 on October 31, 2008, 08:31:52 AM
I have an old Superwinch 9000 that I had no problems with until the recent winch kill fest at the TTCW.  It's not the fastest in the world, but it pulls and pulls and pulls.
As for why it died recently, a solenoid locked up due to a melted control wire.  That will be fixed, and probably mount some larger starter solenoids from Cat in there.  :P
Title: Re: winchs?
Post by: Lindenmooch on October 31, 2008, 11:20:10 AM
I recently bought a Hi-Lift 48" Jack to winch myself out if I get stuck.   Cost 70 for the jack...and around 20 for some tow straps.   Didn't get to use it yet...but it's tested to 7k pounds, so I can't see it not working.   I don't have the money to have such luxuries as a "winch".   :P
Title: Re: winchs?
Post by: 1badzuk2 on November 04, 2008, 11:04:11 PM
dude that high lift wont work to good if ou get stock in mudd been there did that.  Im a big boy and that thing gets hard as hell to pump when you get a load on it me an 3 other people couldnt get my sammy out of mud high lifts are ok for lifting not winching
Title: Re: winchs?
Post by: Lindenmooch on November 04, 2008, 11:10:50 PM
That's not very good news.
What about a come along?
Title: Re: winchs?
Post by: bzzr2 on November 05, 2008, 10:16:08 AM
depends on the come along.  i have an industrial lift/come along rated to 16000lbs or something ridiculous, have used it when a winch wasn't cutting it.  tried an el cheapo this year and it didn't do the same thing, was much more difficult to work with but did work in relatively easy out stuck situation.
