ZUKIWORLD Model Specific Suzuki Forum => Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005 => Topic started by: giacomo.m on October 06, 2008, 12:50:54 AM
Title: GV front diff broken
Post by: giacomo.m on October 06, 2008, 12:50:54 AM
Hi all,
I am owner of GV 3 door LHD 2001 with J20A engine, and I have front carrier aluminium broken.
I want to replace it by a more solid carrier.
therefore the steel axle of 2.0L TD Vitara 5 door it is compatible with my front drive shaft RH and shaft front drive ( in housing differential ) ?
thank you.
Giacomo
Title: Re: GV front diff broken
Post by: Frank84 on October 07, 2008, 06:03:34 PM
While I'm not familiar with the diesel, I'm 99% sure the answer to your question is YES.  The steel assembly is bolt in for the aluminum and the axle shafts will transfer.
Post by: IanL on October 08, 2008, 01:06:16 AM
Make sure you have the right gears to match the rear!
Post by: giacomo.m on October 08, 2008, 01:16:19 AM
thank you
but differential ratio   them is the same one? 4.875 or 5.12 ?
Giacomo
