ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Hawkeye Huey on October 31, 2008, 12:36:04 PM
Anyone know what the center of bushing to center of bushing length of the kick rear lower arms is?
About 19"
Kevin
Thank you I found a site that can make the lower arms with flex joint, just needed the length. They can also make the upper arm with flex joint. they call it a wishbone. Here is the link check it out. http://www.suicidedoors.com.
look in the 4-link parts section.
Thank you I found a site that can make the lower arms with flex joint, just needed the length. They can also make the upper arm with flex joint. they call it a wishbone. Here is the link check it out. [url]http://www.suicidedoors.com[/url].
a wish bone is for the rear end and requires the 2 lower trailing arms still be attached
commonly used on hydraulic cars for taller standing 3 wheel
in other words if your talking about it on the rear end you will still need the lower trailing arms it cannot be put in place of these and if your going to try and use it for an arm
well??????.....
examples of a wishbone suspension
(http://i24.tinypic.com/9knlzl.jpg)
(http://i23.tinypic.com/25umk4y.jpg)
(http://i20.tinypic.com/2j34rus.jpg)
There not all that hard to make. I made some with joints from Ballistic Fabrication. www.flickr.com/photos/bentparts.
Bentparts, Yeah, it looks simple. Kicker is I don't have the skills/tools needed. And not too many people offering to make them in here. Maybe this will change. I would rather have a fellow Zuker make my stuff. They at least have an intrest in the outcome.
i dont understand your application
I make them ;)
I make them ;)
im capable of building them myself i was just trying to understand his application
you should reinforce the center section ive seen many break there and IMO offorad is going to be more abusive then some lay and play in a lowrider
My application is offroad crawler.
Regarding the upper link of the rear suspension, the frame ends are not symetrical to the centerline of the vehicle. IIRC the driver's side is closer to the vehicle centerline to make room for the stock muffler. If you have some one like suicidedoors.com build it for you they will need detailed dimensions, etc.
Mike
