ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Armour on December 10, 2008, 04:42:34 PM
I am looking to put some t case gears in my trackick! Any recommendations on who's to use!
The only gears available for the TracKick is the 4:1 gear set. Just give Low Range Off-Road a call and they can hook you up.
One thing to keep in mind is that the high range is NOT reduced like it is on the Samurai T-Case kits. Only the low range.
Sorry about the misunderstanding! I knew that the onlt gearset is 4:1 and that it onlt effects the low range! What i was refering to was, are there better manufactures then others! For example are Calmini better then Low range! Or all they basically the same!
Should be 4.24:1, but who's counting. Go with Trail Tough. Fast, friendly, knowledgable service, and you'll save a couple hundred bucks, which goes a long way if you're having your favorite driveline shop do the install.
Trail Tough x2. Abuddy and I put them in his kick with a twin stick in a day.
Both TT and Low-Range have good reputations.
Your OTHER option is to do dual cases (sami behind kick), but that will instantly give you 40% reduction (kick hi-range = 1:1, samurai = 1.4:1) in hi range... so... unless you're planing on running some 35" tires, it may not be your thing.
here is the installation article we have, just incase you haven't seen it.
http://www.zukiworld.com/month_010103/feature_calminirockcrawler_sidekick.htm
The installation is actually really straight forward. While you have the case apart I would install a twin stick if you can get one.. 37kicker had them but I haven't spoken to him in awhile and I am not sure if they are still available. I think if we bother evil twin enough they will have a DIY kit on the market before to long. I love my gears and I love my twin stick even more!
I have run both calmini and trailtough gears and I have been happy with both. Trailtough periodically has their gears on sale and they even may be right now for the holidays.
Hutch
