ZUKIWORLD Model Specific Suzuki Forum => Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005 => Topic started by: MBB77 on December 12, 2008, 03:20:16 AM
is it ok if i put 235/70R16 front and 255/65/R16 rear on my GV 04
Noy if it's a 4x4.
only if the diameter between the two tires is the exact same.
Noy if it's a 4x4.
This also may mess up the ABS if you have that too.
Noy if it's a 4x4.
Man, that's a good point. It definitely noticed when I went with a stock-sized spare for a while.
thanks for your replies
the tyre 235/70 is 164.5 and 255/65 is 165.75
so what doyo think
Only ok for 2WD.
If you try 4WD, even on very loose surfaces, the tires will be constantly slipping because of the different speeds, so you will get no traction improvement at all.
thanks for your reply
i'll go to 235/70 only
