ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: HotRod on August 23, 2004, 05:22:11 PM
Title: Yota axles on SideKicks.
Post by: HotRod on August 23, 2004, 05:22:11 PM
I'm looking for anybody that has put Yota axles under their Kicks.
How they did it. basicly.
How to deal with the steering issues and T-case Slip yokes.
I'm thinking of  just going with the leaf springs (should make it easier)
I don't think I can aford a Kicker 3 yet. Or not for a while.
Any pics or links would be helpful.
May be a winter project.
Title: Re: Yota axles on SideKicks.
Post by: zookiemike on August 23, 2004, 07:01:56 PM
Same  Q's. I dont own a tracker anymore but always wonderd. ;D
Post by: TomKat on August 24, 2004, 03:22:24 AM
http://www.cs.umass.edu/~glenn/personal.html heres a link to my friend Glenn's page. Works REALLY  well.
Post by: HotRod on August 24, 2004, 12:17:23 PM
I'm thinking about just using the leafsprings being I wouldn't have to worry about finding hiem joints (and cheaper) and doing any fancy welding..
In Theory that is.
In theory I'm planning on just rolling the axels/wheels  and leafsprings already on it and find out where to brace/weld.
Post by: 90Stomper on August 24, 2004, 02:54:42 PM
i love that guys site, but, yah i know.... i want to do the leaf thing too.  it looks a lot simpler,  but i know how that goes too.  what axels did heather use and what is the link to her 'how to'? ???
Post by: HotRod on August 24, 2004, 03:15:28 PM
Good one. I've heard some people actually use Sammie leaf springs when the do the SAS on Trackers.
As so I've heard some where from some one.
I suffer from C.R.S.
Post by: explosivo on August 24, 2004, 05:14:55 PM
That's how digger's kick is set up... SPOA with sammy rear leafs...
Post by: HotRod on August 24, 2004, 06:51:29 PM
Well, the more pics That can be found the better. I'm not a great Fabercater but I can weld on a spring hanger. I have some pics but I don't know where they came from. anybody know?
(http://www.eye-irritant.com/august2004/leaf1.jpg)
But the front of my frame doesn't look like this. ???
(http://www.eye-irritant.com/august2004/leaf2.jpg)
Post by: 1bigtracker on August 25, 2004, 04:21:59 AM
that looks like some nice work!  looks like they where stamped brackets.
stu
Post by: HotRod on August 25, 2004, 05:42:08 AM
I'm hoping to find out where these came from and see if they were prefabracated brackets and find out more about them.
Post by: hcgalvin on August 25, 2004, 06:04:21 AM
I use a hybrid setup, taking two axles, a sammy front and a sidekick rear. I used the sidekick rear middle section, so that I could put a bigger kick rear diff into it, and used the sammy ends with the birfs. I also got Brent at TT's "double tough" subaru birf setup, and I am running OTT custom chromoly axle shafts.
The main reason I went with a hybrid was to stay mostly suzuki, as well as the axles being readily available to me.
A cheaper way would have just been to go with a sammy front end, and lengthen one side. You could put the smaller sammy diff in it, and you'd only have to buy one custom axle shaft for the side you lengthened.
I guess I went with the way I did because it was beefier, and I would only have to keep on hand one 3rd member that could be used in either end. I know mine is a little more custom, but it seems to work.
We went with leaf springs because they were cheap and easy, we didn't need to fabricate a link set up, and they are easy to adjust to ride comfort and flex (ie add a leaf or take one away).
You can always find everything about my truck by just going to the link in my profile. However, here's a straight link to the SAS setup stuff:
http://www.whitepineclub.com/members/kd7hcg/pictures/SAS/index.html
Hope this helps.
Heather
Post by: 1bigtracker on August 25, 2004, 06:08:19 AM
([url]http://www.eye-irritant.com/august2004/leaf2.jpg[/url])
thats not a tracker frame.  off the top of my head, it looks like a trooper or Raider frame.
stu
Post by: TomKat on August 25, 2004, 09:39:43 AM
stu
I think it's a toy SAS project. Looks good, though, nonetheless.
Post by: HotRod on August 25, 2004, 12:21:05 PM
I just don't remember where I got the Photo from. But the Brackets look like they would be nice to have ;D
                                                 (http://www.eye-irritant.com/august2004/tracker%20SAS.jpg)
This is from Cardomain. I know he was here once but he had a shop do it for him so info is lacking :-/ And my frame don't look like that either. ???
Post by: jagular7 on August 26, 2004, 10:13:51 AM
The pics I had in my photos in webshots and on my computer. Computer is down for a few more days and I'll check the files to see what the properties are. IIRC it's a full size GM frame getting a SAS performed on it.
Post by: HotRod on August 26, 2004, 03:13:14 PM
Good plan.
Heres a plan I just thought up.
If there are Companys that make coil kits for Sammies with Yota axles. Couldn't I buy kit like that so I would have all the parts and just make them fit my Tracker?
I guess I should call around to shops and see if thats possible and cost effective.
Post by: HotRod on August 26, 2004, 04:10:44 PM
So far from what I've found is only RRO has a coil spring setup. Am I missing somebodyelse?
Post by: 1bigtracker on August 26, 2004, 04:29:19 PM
i have never seen anyone else. ???
stu
Post by: idaholwb on August 26, 2004, 05:10:42 PM
 Call Brent at Trailtough, he has a kit almost done if not done for doing just that. It has everything you need to accomplish the Toykick SAS coil swap. He told me that there is minimal welding that needs to be done. The spring pads for the leaf springs that are on the stock Toy axles are the centering point for the control arm mounts on the axle. You bolt the mounts to the housing, then you weld them on. The rest is a bolt on to the truck. The kit comes with steering, shocks & mounts, brake hoses, I think it might even come with drivelines, not sure about that one, all the control arms & mounts, coils & buckets, might be more, can't remember right now it's been a while since that conversation came up. You'd have to call him on the price, keep in mind that it is a bolt on kit that is very complete.
Hope this helps.
Post by: HotRod on August 26, 2004, 06:06:28 PM
Am all over that. I'm going to shot them an Em right now.
Thank you Idaholwb
Post by: ksa421 on August 29, 2004, 12:25:14 PM
I have seen Trailtoughs SAS Kick it is a sweet setup. It sit on 35s with no body lift and they can lift the rear tire 3ft off the ground. Also when the tire is stuffed in the wheel well there is an even 3/8 of and in between the tire and the fender all the wat around. Last time I talked with Brent they where in the process of blueprinting it. It looks pretty trick.
Jacob
Post by: HotRod on August 29, 2004, 01:46:06 PM
Well, I've E-mailed TrailTough thursday and no reply yet. I did get a reply from RRO. Not promising but they say its possible.
(Wish TrailTough would respond b-4 I change my mind.)
Post by: cj on August 29, 2004, 04:24:10 PM
Any pics of the Trailtough SAS?
Post by: cj on August 30, 2004, 07:31:20 PM
So, the Trailtough kit won't be available till next year.
Post by: HotRod on August 31, 2004, 06:14:12 PM
Ya. Thats what I just heard.
I guess It wasn't suppose to get out of the bag till next year.
I'll have to try and  wait till next year.
Post by: HotRod on September 09, 2004, 06:23:07 PM
Well i got another reply from TrailTough tonite and they said they have a few projects to get done first but the do have a prototype up and running. So they took my Phone# and said as soon as they are ready (next year, hopefully by spring)  they"ll call ;D ;D ;D ;D ;D ;D ;D
So I'll wait till next year and do it right.
"WOW", next years tax refund is already spent ;D
Post by: Mike71 on September 09, 2004, 06:55:56 PM
do u happen to have pictures of the trail tough rig?
Post by: HotRod on September 10, 2004, 12:54:27 PM
I wish. But I'm gonna Em them again and ask.
     I' have no Idea what is involved in their SAS but I'm sure its as good as everythingelse they have done.
