ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: IdahoZuk on January 06, 2009, 04:53:19 pm
Title: Anybody out there have experience with the Harley Davidson carb on Samurai?
Post by: IdahoZuk on January 06, 2009, 04:53:19 pm
I'm trying to find something that is more reliable than a regular carburator and I don't want the expense/trouble of FI.  I also want to gather parts over the next couple of years to install a 1.6L turbo diesel, so I just want something reliable in the mean time without spending a ton.  Thanks in advance for any of your thoughts.
Title: Re: Anybody out there have experience with the Harley Davidson carb on Samurai?
Post by: 96Kicker on January 06, 2009, 08:56:24 pm
My buddy had the screaming eagle 44mm on his samurai,(1.6 8v). That thing hauld ass.
We both had 33's, 6.5.1 t case gears and mine had the 1.6 16 valve with fuel injection. We both could easyly do 80-85 MPH. He did have trouble with getting the fuel pressure just set right.  HE was always adjusting it.You can PM on here he is blknight87.
Post by: phloop on January 06, 2009, 09:00:47 pm
You can cobble up a home brewed kit but it will have issue's. The best way is to get the MS1 as it has the kinks worked out. And a used HD carb off of egay will make the kit fairly cheap. And besides, when you do the engine swap you can resell that MS in a heart beat.
Post by: Spinnaker on January 07, 2009, 09:07:12 am
I built my own CV carb setup and I really like it.  I'm into the whole setup for under $110.  I got the carb off of ebay and fabed my own adapter.  It pulls MUCH harder than the stock setup (which ran fine).  I have to be careful not to rev too high now...  I can bounce it off of seven grand way to easy.
(http://i71.photobucket.com/albums/i155/Spinnaker_88/Samurai%20Tech%20Pics/100_0763.jpg)
(http://i71.photobucket.com/albums/i155/Spinnaker_88/Samurai%20Tech%20Pics/100_0766.jpg)
(http://i71.photobucket.com/albums/i155/Spinnaker_88/Samurai%20Tech%20Pics/100_0770.jpg)
(http://i71.photobucket.com/albums/i155/Spinnaker_88/Samurai%20Tech%20Pics/100_0771.jpg)
(http://i71.photobucket.com/albums/i155/Spinnaker_88/Samurai%20Tech%20Pics/100_0774.jpg)
The last picture is not too accurate.  I ended up having to cut the adapter a bit shorter was the carb was just barely touching the hood cross member.  I ended up fabing my own air filter adapter to run a UNI dirt bike foam filter.  If I had to do it again I would just by one of the open element filter setups that they sell for the cv carbs...  I do like the UNI for the fact that it ways very little.  I had to mod the carb just a slight bit.  Here is the video I made about the mods...
http://www.youtube.com/watch?v=CXKUT9HeRnM (http://www.youtube.com/watch?v=CXKUT9HeRnM)
So yeah.  If you have questions I'm happy to help!
Tim
