ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: bashzuk on February 10, 2009, 09:25:01 PM
Title: How well would ltb 31x11.50x15's on 15x 8's work in the sand?
Post by: bashzuk on February 10, 2009, 09:25:01 PM
At some point this summer I will be taking my sami down to the dunes in OR and I'm wondering how well my tires will work in the sand aired down?
swamper ltb 31x11.50x15's
Looking for opinions fire away everyone
Bash
Title: Re: How well would ltb 31x11.50x15's on 15x 8's work in the sand?
Post by: jstrong89 on February 10, 2009, 09:42:13 PM
Those Swampers are heavy duty tires and have thick sidewalls, so you will have to air them way down to get them to work in sand.  If you don't bring them down to at least 12lbs you will just dig holes.  I reccomend 10-11lbs and they will do great.
Post by: trevorsride on February 10, 2009, 10:23:19 PM
Should be fine, but I would go down to 6 or 8 lbs. I run my Jeep at 6lbs out there with 33s, and the difference between 6lbs, and 10lbs is night and day.
Post by: bashzuk on February 10, 2009, 10:35:37 PM
I run them on the trails at 6 psi
Post by: Skyhiranger on February 11, 2009, 06:13:18 AM
I would run them at 5 psi or less (as long as you can keep them on the bead).
Of the swampers I have had, I've had to run them at 5 to get any noticeable bulge in the sidewall.
Post by: trevorsride on February 11, 2009, 08:01:48 AM
One of my freinds had a set of thornbirds, and he would acually pull the valve stem core and run them at 0. They were so stiff they still didnt bulge much.
Post by: lil_Truck on February 13, 2009, 04:19:11 AM
In the Tracker I run 6 up front and 4 in the back on the sand (32 MTR's)
Post by: Bigzook on February 13, 2009, 08:20:16 AM
5-8 pounds is good. You will want more power though. Still a lit of fun. Where are you going exactly?
Post by: bashzuk on February 13, 2009, 09:58:14 AM
Florence OR
Post by: Yankee-Tim on February 13, 2009, 10:20:55 AM
In sand, the wider the better.
Post by: boogner on February 24, 2009, 10:34:05 PM
I don't have much sand experience in sand . If you run tires designed for desert use would would you still have to air down? The reason I ask is Stone Tire has a set of tires called Ugly Dogs with desert tread. These are retreads wont set you back to much. Put em on rims and swap them when you go to the dunes.
