ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Armour on February 18, 2009, 04:49:27 PM
Title: Alternator question.
Post by: Armour on February 18, 2009, 04:49:27 PM
I am doing the GM alternator upgrade to my kick. Mine runs the ribbed alt belt. Can I use the ribbed belt on the gm alt or do I have to switch all the pulleys to v belt?
Title: Re: Alternator question.
Post by: ROSS on February 18, 2009, 05:14:09 PM
thats what mine is .  i believe its off a 97 to 02 pontiac . 105 amp
works great on mine i run dual batteries
Post by: Armour on February 18, 2009, 05:32:41 PM
What ribbed or V belt?
Post by: ack on February 18, 2009, 05:57:14 PM
GM SI-series Alternators are available with the flat ribbed belts and old-school v-belts.
The best way to get the right alternator is to go to a Pick-N-Pull salvage yard and "harvest" a unit that has the type of pulley that you need.  If the alternator turns out to be a "dud", you can use it as a core to buy a new/remanufactured one.
Watch out, though, you may need to "clock" whatever alternator that you get so that the electrical connectors are pointing in the right direction.  If you are unfamiliar with "clocking" an alternator, visit your local parts store and ask the "Old Guy" behind the counter.
Do a search for alternator at ack's FAQ (see sig) for more info.
Post by: ROSS on February 18, 2009, 07:17:23 PM
ribbed or actually its called serpentine
Post by: mike5721947 on February 18, 2009, 08:06:15 PM
accually they are different..
theers v belt, ribbed, and then serp.
v belt and ribbed both use seperate belts for each accessory. serp uses one belt, looped through several accessories and idler pullies to run. (serp is tensioned by a tensioner pully that puts the propper tension on the belt. vbelt and ribbed both use physical movement for the accessory to tension the belt.)
Post by: Armour on February 18, 2009, 09:13:46 PM
Thank you Mike. That was what I was going to reply, in a nutshell.
