ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Spitfire Rick on March 11, 2009, 06:18:05 PM
Title: distributor swap
Post by: Spitfire Rick on March 11, 2009, 06:18:05 PM
will a distributorfrom a 1.3 fit into a 1.6 8v
Title: Re: distributor swap
Post by: Rhinoman on March 13, 2009, 07:10:17 AM
You need to use the adapter from the 1.3 or grind the end of the shaft off the dizzy.
Post by: ebewley on March 13, 2009, 09:09:19 AM
Are you sure Rhinoman? I think that the 1.3 dizzy from a Samurai installation will slide right into the 1.6 8-valve Sidekick / Vitara engine. I'm not 100% but I think I've done that though...  ???
Post by: Spitfire Rick on March 13, 2009, 09:49:25 AM
 I just swaped distributors the 1.3 was longer than the 1.6 below the gear I just swaped the adaptor only 3 bolts 1.3 dist. is now nicly installed on 1.6
