ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: hardin316 on March 25, 2009, 04:09:35 PM
I have a sammy with a 4.3, stock axles, and plan on 35's (some day) but i need help on what power steering gear box to run and maybe a tech article and/or pictures if possible please
thanks
The easiest would be to use the Tracker power steering. Or you can modify up a Toyota conversion. Acks Faq probably has a few write-ups.
For a 35" tire i would go with Toyota power steering, the trakick power steering is a little bit small for that size.
I mounted up a Toyota IFS power steering box and pump, if you have any way of welding/minor fabricating its not very difficult to do.
Here is the IFS box mounted
(http://i49.photobucket.com/albums/f261/rellim87/Samurai/IMG_0297.jpg)
Stock pump before cutting into it.
(http://i49.photobucket.com/albums/f261/rellim87/Samurai/IMG_0301.jpg)
Motor side of the mount.
(http://i49.photobucket.com/albums/f261/rellim87/Samurai/IMG_0302.jpg)
Altered pump bracket.
(http://i49.photobucket.com/albums/f261/rellim87/Samurai/IMG_0303.jpg)
Pump installed with trail toughs double V pulley.
(http://i49.photobucket.com/albums/f261/rellim87/Samurai/IMG_0305.jpg)
Top view, used a car quest belt (part# 7330)
(http://i49.photobucket.com/albums/f261/rellim87/Samurai/IMG_0304.jpg)
Added a big ass power steering cooler too.
(http://i49.photobucket.com/albums/f261/rellim87/Samurai/Cooler.jpg)
So far it has all be working great for me, no problem turning my 34 LTB's at idle. While at a stand still in the rocks you do have to give it some low revs to turn it with out killing the engine...but thats with a stock 1.3L
Not sure if this is the rout you are willing to take, just tossing around some ideas .
Amilla
I have a sammy with a 4.3...
i would say use a ps pump and box off an s10 or fullsize chev... it all mounts up to the engine and would work the same as mounting the toyota box
Wow i completely over looked the 4.3, ya man use what ever bolts up to the 4.3.
Amilla
Good call on the 4.3, I completely missed that as well. :)
Are you doing any sort of axle swap? Or do you plan on running a 4.3 with 35s with stock axles?
Amilla
probably doing yotas in the winter but i may try the chromoly shafts from lowrange bc right now i break birfields on command
