ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Sidekick Kid on March 25, 2009, 07:41:30 PM
Hey, i have a 1993 4 door suzuki sidekick. And i was wondering if these will fit with no problems, like rubbing or anything..
http://vancouver.en.craigslist.ca/pts/1074320187.html
Thanks.
The short answer is NO, you will not be able to run 31's on a completely stock sidekick without major rubbing and possible tire failure due to the fender wells cutting into the tire itself.
Also, you would want to learn more about the rim, particularly what 5 lug dimension these are. There are several 5 lug configurations, and only 5 lug with a 5 1/2" lug pattern will work on a Sidekick. If these are 5 on 4.5", they are more than likely meant for a Jeep TJ, etc. If you ask them what they came off of, you can probably deduce whether they would fit or not. Vehicles like older Broncos, and Jeep CJ's use the same 5x5 1/2 pattern that we use.
If you are considering 31" tires, there are several ways in which to accomplish this. Budget, vehicle condition, and mechanical ability all determine what approach you would take to lift your vehicle.
Hopefully this helps a bit. If you want/need help on lifts, all of us on here can help you determine what would be the best approach.
-Zukisidekick
Well im looking for 31's, so what would be the cheapest way to lift her up about 2 inches, assuming a 2 inch lift would be enough for the 31's. Would it?
To effectively clear 31's, and to minimize the amount of needless body trimming, a 4-5" lift is ideal. Typically, it's a combination of 2-3" body lift and 2" coil spacer lift. Here's a link to a very cost effective 5" combo that will allow you to get 31's under your rig without breaking the bank.
http://www.zuwharrie.com/content/view/11/27/
Thats alot for that link, ill read it all. Thanks!
