ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Gadzukes on April 05, 2009, 09:26:25 AM
Can anyone tell me what rears will work in my Trackick will a two wheel drive rear work or are the gears different? is there any other rears out there that will work and stand up to the punishment better then the Zuke rears? Thanks
You can get 5.13's in a Ford 9 inch rear axle, the only thing is your rear end will be way wider than your front and you will need to do some custom fab for the mounts and links and whatnot. Best to stick with Zuk parts if you can, unless you're running HUGE tires.
The ford 9" is the best option for strength and being able to stay with the stock gearing. The gear options on the stock axles vary depending on year, engine, manual or auto. A Jeep widetrack width ford 9 is actually narrower than a Kick axle. If you look around you can find one that will work with your ride.
