ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: oak_raid on April 21, 2009, 01:37:44 PM
Title: Failed smog
Post by: oak_raid on April 21, 2009, 01:37:44 PM
I would like to preface this post by stating I am not a mechanic, but I'm not an idiot about cars either.
I picked up an 87 sam last month for $700.  It had been sitting for at least 2 years, but fired right up when I bought it.  It runs pretty darn good, everything works including heater, wipers and so on.
Of course, I tuned it up.  Oil, plugs, wires, cap & rotor, air filter, radiator hoses, fan belt, fuel filter.  The engine doesnt smoke or leak any fluids.  I did the shifter sheets and the tranny bolt replacements.  I thought I was ready for the smog test, but it failed miserably.  Even worse, it was a gross polluter on the 15MPH NO readings.  Here are my readings in ():
15mph, (2106) rpm, (13.7) CO2%, (0.8) O2%, HC MAX 38 GrossPoll 312 measured (234), CO MAX 0.84 GrossPoll 2.34 measured (0.75), NO MAX 859 GrossPoll 2088 measured (2167)
25mph, (2504) rpm, (13.8) CO2, (0.8) 02%, HC MAX 12 GrossPoll 262 measured (188), CO MAX 0.73 GrossPoll 2.23 measured (0.74), NO MAX 798 GrossPoll 1888 measured (1787)
As you can see, it wasnt even close.  I'm not sure where to go from here.  O2 sensor?  cat converter?  Any advice?
Title: Re: Failed smog
Post by: idaholwb on April 22, 2009, 11:02:00 AM
Because your hydrocarbons were so high, try checking all the vacuum lines. I'm betting you have a leak...
Post by: oak_raid on April 22, 2009, 12:00:44 PM
All the vacuum lines seem to be hooked up.  I cant find any leaks.  Is there a way to test the o2 sensor to see if its working?  I ordered a new one, but not sure if i'm on the right track here.
Post by: ppltrak on April 22, 2009, 02:34:34 PM
Put a cat on it all your readings are high. You should also look into egr problems due to your high NOX
   Kevin
Post by: Jeremiah on April 22, 2009, 03:29:31 PM
   Kevin
What he said. It's VERY easy to test the o2 sensor with a $3 multi meter - google "Testing o2 sensor". According to the SMOG guys I knew, it was the most often replaced part that didn't need replacement.
Post by: oak_raid on April 23, 2009, 09:38:33 AM
Changed the o2 sensor, not sure if it was needed or not but it cant hurt.  Going to clean out the egr and replace the cat next.  Thinking of a carb rebuild too, since its running so rich.  Maybe the floats are bad or sticking?
The way I understand it, the o2 sensor relays info to the computer about air/fuel mixture and the computer then adjusts the carb.  There is no other way to adjust the air/fuel ratio?  Is this right?  Do i need to reset the computer after replacing the 02 sensor?
Post by: Jeremiah on April 23, 2009, 10:12:01 AM
Changed the o2 sensor, not sure if it was needed or not but it probably won't hurt.
Fixed.
Take it from someone who's done repair work virtually all their life - replacing a part in an unknown working condition, and assuming the new replacement part works out of the box can be a source of future troubleshooting frustration. I'm not a fan of replacing parts which may or may not be working - especially when it takes less time and effort to test the part than to replace it (http://wps.com/LPG/o2sensor.html). But, that's just me. In any case, although the odds are against it, it's important to be aware you may have replaced a properly functioning part with a non functioning one.
Get your hands on a FSM, or Chilton manual. They've got some thorough & easy ways of testing your SMOG system. It'll take you the better part of a day to test everything, but it's worth it. The two most "specialty tools" will be a $3 multi meter, and a $20 vacuum pump.
Post by: oak_raid on April 23, 2009, 10:50:47 PM
well, while I guess its possible the new o2 sensor could be defective......theres a better possibilty it aint.  For now, I'll take it for granted the new one works.
I'll get a multi meter and test it anyway.
Post by: freeriders98 on April 24, 2009, 10:26:49 AM
Check you choke, it may be stuck. Mine was. And I don't know where you live but in Arizona you can get a 1 time waiver saying that basically you are working on fixing the problems, but don't have the money to do it right away. So they'll waive your smog test for 1 registration period. That way you can get it registered and driving and fix it up as money allows. This is not something they offer as a solution. You have to ask them about it. And a vehicle can only be waived once in its life time.
Post by: oak_raid on April 24, 2009, 11:30:35 AM
The choke is working.
California will not waive the smog.  I have an operating permit that expires 5-31-09.
Post by: dowry on April 28, 2009, 01:17:59 AM
I went through this heck with a sami that sat 5 years and then wouldn't pass smog in CA.
Here's some reading that could help:
http://forums.turbobricks.com/archive/index.php/t-154414.html
which also references this:
http://www.smogsite.com/calculators.html#lambda
According to this calc, you're way too lean at both test points (assuming everything else is running perfectly, that is).
No guarantees, but IMHO your combustion temp is too high (not your coolant temp).  This is caused by running too lean or too far advanced timing.
Do the easy things first.  Check that your EGR valve is cycling.  Start the engine and cycle the throttle when warm.  You should be able to see and feel (hot!) the EGR diaphragm cycling in and out in response to changes in RPMs.  If not it needs a cleaning.  Next, samis are famous for clogging the head passage that runs between the EGR valve and the header.  Remove the EGR and inspect for tons of soot and carbon; don't damage the gasket.  Many claim you can't clean this through-head passage with the header installed, but I've cleaned a lot with a fraying length of aircraft cable and a gentle hand.  Then start the engine with the EGR valve removed and see if plenty of exhaust blows out (loudly).  If so, it's clean.
Next check your 02 sensor with a DVM.  Also, probe the connector at the ECU to confirm that the 02 signal is getting delivered to it (rules out a harness problem).  You'll need a wiring diagram for this.
Another common cause of high combustion temps is a vacuum leak, which is why everyone's suggested you check for one.  An easy test for a vacuum leak is to probe every possible leak site with the tip of an unlit propane torch (do this outdoors) while the engine idles.  If the RPMs increase you've found your leak.
Another source of too-lean could be a maladjusted carb mixture screw, but that's a PITA to deal with so let's save that for last.
Too-advanced timing could be a problem, too.  Did you replace the timing belt?  Samis are known for running (but not well) with the timing belt skipped one tooth.  Also they wallow out the crank pulley keyway making them un-timeable, so I'd check this.  Also, you didn't mention a valve adjustment, but I'd do one on any new sami I got to make sure that all the valve hardware is properly tightened, as some parts are known to vibrate loose (but I don't see how the valves would cause your smog problem, however).
You can ask a mechanic to check your cat by pulling the O2 sensor and having him wand the tailpipe and then the O2 bunghole.  This tells exactly what difference the cat is making.  I'd bet yours is having no effect on your NOx.
There's also a ton of switches and sensors that the FSM will send you off to test, and any one *could* be the issue, but with the NOx so high, I'm guessing the problem isn't in your control system or adjustments, but in the plumbing (a leak, clog, bad cat, etc).
The suggestion to get a FSM is a good one.
I don't see how a stuck choke could cause high NOx or a lean condition, but I'm no expert.
HTH,
D
Post by: oak_raid on April 28, 2009, 08:15:30 AM
Thanks, Thats alot of good info
Post by: xkmail on April 28, 2009, 09:22:32 AM
Hi NOX is typically a cat converter failure.
If it is carbb'd and running rich, that killed your O2 sensor and cat.
a dirty egr is quite possible too running rich.
A simple mechanic with scope can check the carb at the tailpipe to see if it is rich.
have him do a  drop cylinder test, if you have low compression then a cylinder is not burning all the gas, you will fail smog till the cows come home.
If rich try to adjust, other wise rebuild, then recheck.
If then nox are high look at 02 ( check with voltmeter) then cat.
check spark plug wires with voltmeter and plugs, distributor tune-up.
Post by: oak_raid on April 28, 2009, 12:34:23 PM
I have a hard time believing it is too lean.  I can smell fuel from the exhaust.  Too me it smells rich, not lean.  Also, there is some dirty brownish-black liquid spraying from the exhaust if you race the engine, mostly when he engine is cold.  I didnt notice it at first, until I had my GMC parked behind it while I was working on it.
I removed the egr to check for blockage and the passages were clear.  Put it back on and ran the engine to norm temp, and I can see the valve opening slightly when the engine is revved up.  Not sure how much it is supposed to move.
I have checked and rechecked for vacuum leaks and cant find any.  A friend came over and said you can take the cover off the carb, and cover the carb with a cloth to check for vacuum leaks.  He said if the engine bogs down when the carb is covered then you have no leaks.  I had never heard of this before, so I dont know how accurate this is.  But he tried that and said I have no vacuum leaks because the engine bogged down when he covered it.
I have an FSM, but reading it and understanding it are two different things.  Maybe Chiltons would be easier to comprehend.  My gut tells me the cat is bad, could this be why the brownish liquid is spraying from the exhaust?  It aint alot of fluid, but it is noticeable.
Also, when I replaced the spark plugs, they were black...real black.  All of them.
Post by: Jeremiah on April 28, 2009, 03:11:37 PM
FSM is easier for me to understand than Chilton. FSM usually has more detail & more pictures. Chilton's directions tend to be more generic. But, that's me. What part of the FSM are you having a hard time understanding? Learning how to read that manual will help you diagnose your vehicle (this and future purchases) with confidence anywhere - anytime.
Post by: oak_raid on April 28, 2009, 05:19:19 PM
The FSM just seems to jump around alot.  Like it tells you what to check, but not how to check it or where to find how to check it.
Its probably just me trying to read it too fast.
Post by: ppltrak on April 28, 2009, 08:55:17 PM
Check Your EGR it is the main NOX reducer.
Post by: oak_raid on April 29, 2009, 05:04:27 PM
Taking it tommorrow to have diagnostics done on the engine.  I'll update this when I find out more.
Thanks for all of your advice.  Sometimes just typing out your problems helps, lol
Post by: oak_raid on May 02, 2009, 09:59:30 AM
Found out a few things.  First, I have no vacuum leaks.  The EGR is working.  The carb needs rebuilt or replaced.
Been looking at prices for carbs.....they are pricey!!
Post by: oak_raid on May 03, 2009, 08:01:42 PM
Picked up a rebuilt carb, still attached to the intake manifold.  since most all of the vacuum lines were already hooked up, figured it would be easier to change the whole intake rather than just the carbs.
Put it on today, cant get the intake to stop leaking.  Gonna haveta take it back off tomorrow and start again cuz I broke one of the bottom studs trying to get it to stop leaking.    :o
Post by: oak_raid on May 04, 2009, 09:22:24 PM
Well ok, I got the intake all fixed up.  I had thought the truck ran good before, but what a difference!  This baby is purring like a kitten now.  Gonna run some cleaner through the system and try smog again.
Also picked up a set of 5 BFG LT tires from the same guy I got the carb from.  They look sweet!
Its coming together nicely.
Post by: Drone637 on May 05, 2009, 12:39:24 AM
It's amazing how much of a difference a clean carb can make.  Good to hear it's back on the road.  :)
Post by: pershingd on May 07, 2009, 05:12:27 PM
As I was reading the posts, I was thinking the carb needed work. I was going to recommend replacing it unless you had the guts to rebuild it, but you beat me to it.
Glad to hear you got it running better - I hope it passes smog testing for you.
David
Post by: oak_raid on May 07, 2009, 09:04:33 PM
yeah, it made a big difference.
I put some G2P in the tank and have been running it through the system.  I can still smell a faint odor coming from the exhaust, but I think it is the G2P.  At least I hope it is.  The truck seems to run better every day, the power is really coming back.  I have taken it on the freeway numerous times, and havent had any problem getting it up to 65 mph.  It would probably go faster, but I aint pushing it.
 I still get a little (very little) gray smoke from the exhaust at cold startup, but only if I race the engine up.  The brownish fluid I had talked about coming from the exhaust before is gone though.
I have been doing some reading on the seafoam, and am wondering if I should do this treatment as well.....
Post by: oak_raid on May 14, 2009, 10:01:13 PM
just to update.....
Took it this morning to test only station.  It failed again, almost as bad as the first time.  Not a gross polluter, but close.  It failed every measured reading, HC CO and NOx.  Took it straight to a muffler shop and had the cat replaced.  I knew when he cut the old cat out I had found my problem.  It had absolutely nothing inside.  NOTHING, as in you could see all the way through it.  He put a magnaflow cat in and I took it straight back to the smog station and retested it.......
Not only did it pass, but the numbers were so low it was almost unbelievable.  HC readings at 15 mph was 0 and at 25mph was 4.  The NOx where i was originally a gross polluter at 2100+ was down to 13.
So, I guess I should have went with my first instinct and replaced the cat right off.  $500 later I got it right  ::).  Went to DMV and picked up my plates and registration.  I'm good to go.....now on to the fun stuff!!
Post by: Drone637 on May 15, 2009, 02:10:26 AM
Sometimes it is amazing how much of a difference a cat will make...
