ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Jookycola on May 05, 2009, 02:36:01 PM
Title: will samurai wheels fit a kick??
Post by: Jookycola on May 05, 2009, 02:36:01 PM
The reason i ask is i'm on the hunt for some new shoes for my trackkick.  but it seems if you enter geo tracker or suzuki sidekick in these online rim shops you get like 10 of the lamest wheels on the market.  But if you enter suzuki samurai you get the 10 lame ones and about 8 or more really nice ones.  Why is that?  i was under the impression the bolt pattern and center bore for the hubs were the exact same.
It got me really confussed.
Title: Re: will samurai wheels fit a kick??
Post by: ack on May 05, 2009, 02:44:07 PM
The offset on a samurai wheel is a bit different - deeper, I think - so the Samurai wheel will stick out farther on a TracKick.
I ran a set of Samurai wagon wheels for a number of years on a '96 Tracker with no problems.  You could also run Ford Bonco (full-sized!) spoked wheels on your TracKick.  I got a used pair cheep ($10 a piece) at an all-ford truck salvage yard...
Post by: Drone637 on May 05, 2009, 04:58:13 PM
You can also get wheels from Jeep CJ's to put on there.  Just mentioning Jeep should be good for another 10 options or so.  :D
Post by: jawman on May 05, 2009, 10:07:13 PM
They are all 5 on 5.5 bold pattern, so ford, and dodge all fit on there. I just go down to the wrecking yard and Buy a set of wheels and tires off a ford truck for about $80. It doesn't get easier then that.
Post by: idaholwb on May 06, 2009, 12:02:59 AM
Only issue with running stock Ford wheels on a Suzuki is if they are stock Ford wheels they won't clear the hubs in the front or the 4 bolt pattern on the end of the axle on the rear. The stock Ford wheels use a smaller center opening for some stupid reason...
Post by: Black Zuk on May 06, 2009, 06:15:12 AM
I found the careful use of a hone to remedy that problem. Very careful. But I'm running them now.
Post by: Rhinoman on May 07, 2009, 04:27:07 AM
Samurai is 95mm backspacing, Track?Kick is 110mm.
Post by: Uncivilized on May 07, 2009, 05:02:07 PM
Only on 2WD models; 4x4 models have the large hole.
Post by: Jeremiah on May 08, 2009, 02:19:12 PM
Anyone know of stock Ford / Dodge / whatever vehicles that have good backspacing for larger tires... or is this a search & measure thing at a junkyard?
Post by: Uncivilized on May 08, 2009, 02:38:23 PM
3.75" and 3.5" is fine, just need the wider width. 7" or 8". F150 4x4, Dodge RAM 4x4, Jeep CJ...
Post by: Skyhiranger on May 08, 2009, 07:44:56 PM
Not always.  I got a set of factory aluminum wheels off of a 4x4 Bronco and had to turn the centers out in a lathe (had to take about a 1/4" off all the way around, IIRC), to get them to clear the hubs and the axle/drum bolts/nuts.  And all the same style wheels I have seen on the 4x4 F 150s have the same sized center hole (that is too small).
