ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Lego_Racer on May 06, 2009, 09:59:54 AM
Sounds like your clutch is over-adjusted. Does it make noise when the clutch is pushed in all the way, and does the shifting feel a bit notchy?
When the clutch pedal is at the floor I get no noise when the t-case is in neutral. But when I'm rolling to a stop you can hear as clear as day.
I'm going to check how tight my cable for the clutch is tonight. It was also suggested that it might be too tight.
