ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: cliffy on May 08, 2009, 09:50:13 PM
Have a chance to pick up an 86 tintop, straight, stock, no dents or rust, needs tires and owner says engine smokes like a mosquito spray truck, sitting for years. $1000. Not interested in hard rock climbing just the 1000s of miles of sometimes 4x4 here in N Arizona. Ideas? Suggestions?
Here in Oregon Samurai's sell for about $2000 up to $3000 in good condition. If its strait and is going to pass DEQ, then I would say its not a bad deal. My best suggestion is to look and see what Samurai's are worth in your area and compare.
I would find out what kind of smoke it is spewing, may only need a head gasket or valve guide seals. If it needs an engine you could be looking at an additional $700-$1000 for an engine, as jawman stated, check out your local listings of Sammi's for sale, you may find it is a good deal or not.
Norcal
My thought of course is to do a compression check. Valve seals are a good idea along with head gaskets. It comes with a complete tranny soft parts kit but I'm told nothing is wrong in the tranny. He was going to drop a VW diesel in it but went on to other projects I'll probably know more next week. Thanks
You should jump on that TT. Then when you get, it get in touch with Myron at ZOR out of Camp Verde and get some help with it's issue's.
A $1000 will get you a whole 1.6L swap here. Stock 1.3L engines go for $100 all day long around my area. Short blocks can be robbed from a Geo Metro too. An entire rebuild kit including re-ringing, valve guide seals & a new head gasket should be sub $200, and I can't imagine needing more than $300 in machine work (if any).
Tin tops are especially rare, and in demand. It tends to give 30-100% more value depending on where you live. $1,000 is a pretty good deal, even with a fried engine. Samurais are getting to be quite rare, and it's hard to find ones under $2,000 most places. I just sold a clean stocker for about $3,000 a couple years ago.
I guess it depends where you are, 1K not uncommon here in the Bay Area for an exchange engine ;D
Keep an eye on CL, your local junk yards etc
