ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: 92Sidekick4x4 on June 07, 2005, 04:27:54 PM
Title: well i got my new down pipe....
Post by: 92Sidekick4x4 on June 07, 2005, 04:27:54 PM
well as it says i got my new exhaust down pipe (thanks kreg)
now i need to install it, this could be tricky as i dont have a welder, i was thinking of sliiding a pipe over the outlet on the down pipe then using a exhaust clamp and just tightening it as much as i can and then put muffler cement around the 2 pipes,
what do u think??
i know cheep ass lazy way of doing it ::) ;D
Title: Re: well i got my new down pipe....
Post by: 92Sidekick4x4 on June 07, 2005, 05:57:29 PM
Post by: HotRod on June 07, 2005, 06:05:08 PM
Just do what it takes to get it to a muffler shop then.
A weld will last much longer and give a tighter seal.
Post by: 92Sidekick4x4 on June 07, 2005, 06:10:03 PM
yah i was thinkin ill just make it work to the muffler shop then get them to do it
Post by: chet on June 08, 2005, 02:43:58 AM
make sure to buff/grind all the rust/corrosion off before putting it together. That way the muffler shop will only have to fire up the welder and be done. If they have to clean it all up it will either cost more or you will get a crappy weld.
Post by: 92Sidekick4x4 on June 08, 2005, 04:24:33 AM
good thinkin! thanks chet
