ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: scooterszuk on June 16, 2009, 09:25:41 am
Title: transmission shifter problems
Post by: scooterszuk on June 16, 2009, 09:25:41 am
fellows when I shift to 3rd gear, my shifter gets stuck and I have to take boot off and adjust the shifter back into position then i can change gears again, I notice it has gotten sloppy shifting, not crisp to engauge anymore. My question is, is the linkage in the transmission screwed or is it the shifter worn out?
Title: Re: transmission shifter problems
Post by: scooterszuk on June 16, 2009, 09:29:04 am
Vehicle is a 1988 suzuki samurai tin top.
Post by: ebewley on June 16, 2009, 10:16:12 am
There is a shift pin that breaks on the Samurai Transmissions. In our Gear Guide section you will find an article that show one of the ways to fix the problem.
http://www.zukiworld.com/month_090102/feature_hawkshifterpinfix.htm
Good Luck, Eric
Post by: scooterszuk on June 16, 2009, 01:32:54 pm
thanks have ordered 1
