ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: Chief on August 15, 2004, 11:28:13 AM
Looking at getting new tires in the not so distent future, so I need to know where they would rub and if I could cut em to fit. I have 30's right now and rub the frame at full lock. I would also be getting a set of 2" spacers, and running the stock alloy rims. I also have about 1-1.5" of lift from spacers.
So where would I rub at??
If anywhere at the back of the fenders would be my guess.
I'm running 31's with 3 inches of lift, in the front it rubbed at the bumper cover until it was removed. Now only rubs on the frame while turning.
The Back would grabb my rear bumper cover as well and at full flex would grab the top of the wheel wells.
what if you put 1.1/8" coil spacers plus 2" wheel spacers, would that solve the rubbing??
biuld a $30 body lift and don't worry about rub. i have a CUOTSM FABBED :) body lift cost $35 or so but mine is 4 1/2" so i had to do some extra work. i also run rocky road spring spacers 1 1/8" and can fit 33's with a little rub at full compression. oh swamper ltb's. yes i did trim some sheet metal off the fornt feders not much.
OK, so some 2" spacers (for the wheels), then 1 1/8 spacers I have and a 2" body lift and some fender massaging will clear 31's. Good to know!!
