ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: zo6gun on August 03, 2009, 03:59:53 PM
Title: Twin Sticks for a Sidekick
Post by: zo6gun on August 03, 2009, 03:59:53 PM
Hey guys....Had my ripped boot repaired, and you guys are right,both the frt. and rear axle are in motion when you follow the instructions on flat towing. Does anyone make a twin stick conversion for the Sidekick ??? you guys are the best........ZO6GUN
Title: Re: Twin Sticks for a Sidekick
Post by: cmays03 on August 03, 2009, 05:29:38 PM
i believe its "37kicker" that makes and sells them. $125 shipped the last time I saw something on here but i cant remember where i saw it. his name is stan. do a search and there is a lot of post on here about it.
Post by: zo6gun on August 03, 2009, 07:40:20 PM
Hey........ Thanks a bunch. "37 kicker" how do I get in touch with you. All the best.. zo6gun
Post by: bentparts on August 04, 2009, 01:55:49 PM
 ;) Search: twin stick, and yee shall find.
Post by: phloop on August 04, 2009, 07:37:07 PM
Some guy named batman has info on a shade tree twinstick for the kick's. Not sure if he is a member here or not.
Post by: zo6gun on August 05, 2009, 01:06:14 PM
Hey guys......I feel like a real putts, but I can not figer out how to PM 37Kicker ( stan ) so I can order a Twin Stick setup. ???  I need help :-[  Zo6gun
Post by: ebewley on August 05, 2009, 03:09:44 PM
When you go to his profile, you'll see a list of links on the left of the screen. Down towards the bottom is a link "send this user a personal message" or something real close to that. Click on it and send...
Good Luck, Eric
Post by: rascott on August 05, 2009, 05:47:33 PM
37kicker made a nice kit. i've been quite pleased w/mine.
Post by: zo6gun on August 06, 2009, 09:30:53 AM
Hey Rascott....
Was 37 kickers conversion easy to install ??? Did it require that you get into the T.case. I'm very interested to do it as I do alot of long distant flat towing, Thanks in advance for the information.......zo6gun
Post by: ebewley on August 06, 2009, 10:11:01 AM
Hey Rascott....
To have two-low, you'll have to get into the case and get the detent ball out of there.
Post by: zo6gun on August 07, 2009, 01:51:35 PM
Hey Guys .....So what you are saying is that I can Have a real neutral without disassembling my T Case?   .....Thank you very much for the information and help!.........zo6gun
Post by: cmays03 on August 07, 2009, 06:00:56 PM
no you will have to pull the case apart to take one of the detent balls out that is between the two shift shafts. you have to take it out because it will not let you shift them one at a time.
Post by: rascott on August 08, 2009, 06:28:45 AM
Hey Rascott....
it did require opening the case to remove the detent ball.
i left the trans. in the car, just removed the t/case.
"kit" was twin stick assembly only. i used a rubber glove for the t/case boot and sewed up my own interior boot.
installation was not easy, but interesting, and some bolts require patience.
Post by: zo6gun on August 08, 2009, 01:23:20 PM
Thank you everyone who gave so freely of thier information. Now if I could get in touch with 37 Kicker to order one It would make my day......Thanks Again All the best...Zo6gun :police:
