ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: philc72 on August 11, 2009, 08:13:28 PM
Title: 2002 tracker 4 door ?s
Post by: philc72 on August 11, 2009, 08:13:28 PM
Hey to everyone out there this is a wicked site with lots of tech info Has anyone heard of using tj spacers also do I need an alignment if I go up 1.5 to 2 inches and if so where do you get the camber adjust bolts Thanks .... Phil...
Title: Re: 2002 tracker 4 door ?s
Post by: Drone637 on August 12, 2009, 10:26:54 AM
People have modified the TJ coil spacers in the past, but these days it's cheaper to just buy a set of coil spacers made for the Tracker.
You will need to adjust your camber a bit after installing the lift, the adjustment bolts can be bought at most part stores or just ordered on-line.  I think we share camber bolts with a VW Rabbit, but you would need to verify that.  If you plan on doing a lot of jumping/hard core wheeling you might want to use a welder to tack the adjustment bolt in place so it does not turn on hard landings.
Post by: ack on August 12, 2009, 03:26:53 PM
Here is a lift kit that just became available in the US through Zuks Offroad:
http://www.zuksoffroad.net/upskirt.htm (http://www.zuksoffroad.net/upskirt.htm)
Available as complete or partial as you want.
Post by: jeff1997 on August 13, 2009, 02:12:49 PM
I make a 2" coil spacers lift kit for your 2002. It will run you under $200 total. PM if interested
Post by: philc72 on August 13, 2009, 04:20:05 PM
definately intetesterd what is pm lol i dont talk onlin3e much where r u located and could you tell me a total in cdn dollars with shipping Thanks....Phil....
Post by: ack on August 14, 2009, 12:16:55 PM
Click on jeff1997 in the upper left side of his post - above.  This will get you to where you can send him a Personal Message (PM).  That way you don't have to expose sensitive info. like address, phone number, etc. to everyone on the Internet.
I hope that this helps!
