ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: mhunterff49 on August 12, 2009, 09:36:26 AM
I just heard that someone modified a calmini suspension lift to work with their sport, does anybody know who that could be and if that is true?
Who did you just hear it from? I would start checking there ???
I said in an earlier post that I believe that one of the Aussies (CJ?) did this. It was on this forum.
Edit: The search on here doesn't work very well but you can use Googles advanced search. I had a quick look and found this:
http://www.zukiworld.com/forum/index.php?topic=10803.0
The V6 was fitted to non-US models.
The only difference is the two front diff drop brackets and I modded mine to suit. Calmini do have the specs for them courtesy of ZeusZuki. You will need to get a couple of the removable front ball joints for the front arms too.
