ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: HotRod on August 05, 2004, 03:38:47 PM
Yes, It will really take me that long.
Okay, mabe a day or two.
I have the 2lo kit and the crawler gear ;D Took out the t-case tonite and sent it with my lil bro to do it at work tomorrow (he as a press at work) ;D
And I'll tell you what. I've rebuilt a np205 b-4 snf that weighed a ton comperred to the Trackers t-case. With one hand I got it out ;D
(http://www.eye-irritant.com/august2004/no%20t%20case.jpg)
Should've washed all the dirt off ;) Took awhile to see again :D
I thought it was easier to take the t-case off with the tranny dropped? How hard is it to do it that way?
Much easier. ;D
remove both shifters, and then remove the 5-speed shifter housing on top of the tranny and then you can get all the bolts out. There is a spacer in the T-case to Tranny which doesn't contain any oil.
The t-case is light enough to hold up with one hand (but it does help to have a second hand, I did ;)).Remove T-case cross member and wiggle T-case off input shaft, just make sure you block the motor up so it doesn't fall down.
(http://www.eye-irritant.com/august2004/shifter%20box.JPG)
You have a body lift, dont you ??? I can take it out seperate in my Kick(3: body lift) but can not get the shifter rail case out of the X-90 (no body lift)
A body lift helps out alot ;D
Does anybody know where  the Xtra ball dedent goes?
I got it all together and I have an extra ball lift over
My book doesnt say where any of the balls go :P.
If you don't have extra parts, you've obviously botched the installation. So you're all good ;) ;D
The RRO 2lo set up came with an extra one of these thingies
(http://www.eye-irritant.com/august2004/t%20case%20shift%20thingie.jpg)
The thingie looks like a twin to the other thingie ;)
It goes on the t-case shift rods.Found where the extra ball goes and its all together now and running (so far ;))
And dang, will it go slow ;D
Hard to imagine how you got along without it now, huh? ;)
Just one of those things you thought you really didn't need till ya got it ;D
Kind've like skidplates ;)
ot to be stupid but..
Cant you run two low the same as 4 low but without your front hubs locked in? Same concept right?
Yea but its a pain in the a$$ to jump out every 4 minutes to unlock. With a manual front locker it will turn pretty hard plus stress front components for no reason, just trail use. I use the 2 LO almost everywhere until I get to my obstical, then click it in.Less stress and sharper turning radius.
Mike
Ya, what Mike said ;D
My only question is whats with the extra piece in the RRO kit? Looks the same as the other one and the kit said it only came with the two rods.
