ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: kloang on August 30, 2009, 07:14:33 pm
Title: 1.6 8v head to 1.3 stock engine
Post by: kloang on August 30, 2009, 07:14:33 pm
OK - I'm totally overwhelmed - Just purchased a 1.6l 8v head with exhaust, FI, all wiring, etc. to install on my 88 samurai stick 1.3l engine.The bolt on looks pretty straightforward but the wiring looks to be a nightmare - Does anyone know where a step-by-step install for the 1.6 8v head to the 1300 would be? What kind of added HP can I expect, or improved MPG? I'll need an alternator and fuel pump I know.
Thanks!
Title: Re: 1.6 8v head to 1.3 stock engine
Post by: Rhinoman on September 03, 2009, 04:40:22 am
The 1.6 head will bolt onto the 1.3 bottom end, you will need to change the cam pulley and the belt. A wiring harness can be bought from Trail Tough or you can strip the 1.6 wiring out. Read up on 1.6 conversions, you will need to do the same work.
Post by: captchee on September 03, 2009, 06:42:04 am
Post by: kloang on September 03, 2009, 08:41:57 pm
Thanks guys! I'm in Canyon City, Oregon. Guess I'll have something to do over the long weekend!
My wife is going slightly nuts - I bought the Samurai a couple of months ago and already have $2k into it! What's the best way to get the head cleaned up?
Post by: captchee on September 04, 2009, 08:03:47 am
kloang
 by chance  did you just buy this from me ?
 ie you picked it up in baker ?
 if so  call me . you dont need to go through all the issues  you will go through by yourself .
 give me a call . i will be home all weekend  working on my side kick .
 i can help you hook the ECM  right up .
I know how daughting  all those wires can be
give me a call
Post by: kloang on September 04, 2009, 06:27:50 pm
 That's me; Small world! I'll give you a call. Thanks
Post by: captchee on September 04, 2009, 07:31:44 pm
Post by: kloang on September 04, 2009, 10:03:19 pm
We'll do. I may take you up on the pump. I will probably be coming your way in the next few weeks.
I'll give you a call tomorrow.
Post by: captchee on September 08, 2009, 07:52:34 pm
 sounds good . tank and sending unit is out of a 95 . pump  is the  the same one that was used on your head .
 ill set it back for you . let me know when your coming through . ill be gone  18th -21st
Post by: captchee on October 01, 2009, 08:21:38 am
kloang
 how are you doing on this ? i never heard back from you . did you get the swap done
