ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: whitfield on August 06, 2004, 04:42:54 AM
A friend just picked up a 2000 model Vitara.  We looked it over and got it running yesterday.  Runs great 56K But Rolled Hard & total loss.  This engine looks to more closely resemble the 2.0L then the Mid 90's 1.6L 16v. ÂÂ
Will the 2000 1.6L swap into the Sammy and bolt to the Sammy Flywheel, Trans, and frame with the Standard 1.6L adapter kit.  ÂÂ
This engine, late model 1.6, has the large Manifold with Pre cat, intake plumbing and filter box on the passenger side, two ignition coils on the valve cover, 5-link rear suspension.  All very cool stuff but all different from what I'm used to.
I thought they had gone to
the 1.8L in that year ???
From the Zukiworld specs page.
Vitara -Introduced in 1999 Available in 2 and 4-door hard and softtop models. economically fitted with a 2.0 liter I-4 engine. ÂÂ
ENGINE
Type 1.6 Liter, 16-Valve, SOHC 2.0 Liter, 16-valve, DOHC
Block Material Aluminum Alloy Aluminum Alloy
Induction System Multi-point Electronic Fuel Injection MPFI
Displacement 97 cu. in.  122 cu. in.
Horsepower (SAE net) 97 hp |removethispart|@ 5,200 rpm 127 hp |removethispart|@ 6,000 rpm
Torque (SAE net) 103 lb.-ft. |removethispart|@ 4,000 rpm 134 lb.-ft. |removethispart|@ 3,000 rpm
Bore x Stroke 2.95 in. x 3.54 in. 3.31 X 3.54
Compression Ratio 9.5:1 9.7:1
SEE A MENU BELOW? IF NOT, CLICK HERE
©2000-2004 ZUKIWORLD online by Specific Hazard Unlimited L.L.C. All photography and content by ZUKIWORLD online unless otherwise noted. Send all comments, suggestions, or questions about this web page to the managing editor. All rights reserved please view our terms and conditions  before use.
It is a 1.6L But it looks nothing like the 1.6L in my 1996 Tracker.
