ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: mudslinger987 on September 01, 2009, 12:34:30 PM
I have a 88 samurai and i am going to be installing a locker in the front and a spool in the rear i was wandering if there is anything else that i should need while i am installing the spool and locker. Will i need to get new seals or wheel bearings?
Any input is appreciated.
gday i would cheak the bearings and seals you wouldnt want have to pull it apart again
i replaced all mine when i put lockers in
I would plan on replacing the seals at least. Nothing is more annoying then tearing it all apart, then tearing it all apart again.
For the 3rd members I normally just use some RTV auto gasket maker stuff. Other then that just read up on the installation and go for it.
