ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: fordguy79 on September 15, 2009, 05:22:37 PM
i have an 87 sami 6.5 gears I've put about 3000 miles on them took it to the coast this weekend on the way home the gears started the wine checked gear lube level is full.
do the gears get louder as they wear in?
Whose gears are they?
US made or Chinese copies?
i got then from low range offroad
If lowrange is where you got the gears, you probably have Trail Gear 6.5's.
The Trail Gear 6.5's seem to be a loud gear set. I added some Lucas to mine and it quieted them down.
Amilla
i will try the lucas did u use the synthetic?
I used the heavy duty oil stabilizer. Before you go to add this stuff to your rig, I would suggest warming the hell out of the oil. The stuff is so thick, its hard to get out of the bottle. Especially if your laying under your rig trying to squeeze it into your tranny or T-case.
So far i haven't found a pump that will handle Lucas.
Amilla
found the problem i will post pics had a gear start losing teeth time for a new set
Starting loosing teeth?!
Must see some pics of this!
Amilla
Amilla, how much Lucas do you use? In your tcase.
I put a little less than half a bottle in.
Amilla
heres some pic's bearing went out to lunch and ate it all lol
Did you rebuild your T-case when you installed the gears? Or are they they stock bearings?
That's no good to see that they took a dump like that. Did you talk to trail gear yet?
Amilla
i reused the bearings yes i was cheep!:( I talked to sean at low range he said box them up and send then in he will send me a new set so i need to order new bearings like i should have done in the first time live and learn lol
Bummer to see the gears went south like that.
Its got to be nice that your getting a new set thou. Just rebuild that bad boy and never look back ;D
Good luck
Amilla
