ZUKIWORLD Discussion Forum => Build Diaries, How-To, DIY => Topic started by: goodyz on October 24, 2009, 06:43:20 pm
It seems like I saw a how-to a long time ago on how to cut out the rocker panels and weld in rectangular tubing to make a "built in" rock slider that looks basically like a really beefy rocker panel. Has any one seen this? I have good fabricating skills, I'm just not sure how I'd weld the tubing in considering the thin metal that's in that area. Any Ideas? I don't want any of the ready available 'bolt-to-the-frame' sliders, I want to fab up my own. Thanks.
Right here! ;)
http://www.zukiworld.com/forum/index.php/topic,22395.0.html
That's what I did with mine, but I angled the ends and capped them...
(http://img34.imageshack.us/img34/8265/dscf0877z.jpg)
I made a reallllllly big mistake on the drivers side. I didn't cut wires or anything, but I wish I would have so I had an excuse to bring the harness in the cab. I put the drivers side on and only welded the outside and noticed it got pretty hot, and I didn't want to melt my wires in the harness, so I stopped with the outside and didn't weld the under-side. Next day, I got hired back at the City and I was doing my fabbing in a fab shop in the next town. Well, after a couple hits, the slider bent and I didn't get to weld the bottom, so It's now floppy on the Drivers side, but the passenger side is perfect and it's held up to some MASSIVE beating.
I have been running on mine for just over a year, the
best most used modification I have done. I used duct tape to hold wires up out of the way, and there were wires on both sides. Next one I do, I will use 2x6 and kick it out a little more, easier to weld the inside, and more to slide on. It has saved the body from a lot of damage.
I run with an 80 y/o wheeler who has been building these sidekicks since they came out, so I told him about the sliders and he was interested, then he said they hang down too much, and his caved in rockers had better clearence, which is true! THEN I had a great idea.... What about 2x4" angle iron?!
Stick down to far? The ones in this topic aren't bolted/welded to the frame, sections of the rocker is cut out, wires tucked up/taped in place, then the box tubing is inserted and welded. It doesn't change clearance hardly any.
That's how mine is and it's not as much clearence as a beat-up rocker panel. Then I figured out we might use 2x4" angle iron... Seems like it's just as strong.
The low point is usually the frame more then the rocker panels. If you want to get more clearance you could cut them out completely and replace it with a 1x4 piece of angle iron but you aren't going to gain much without cutting into the doors. You should take a look at the . I would just run with bashed in rockers if you are worried about clearance. The long term method would be to cut the rockers out and the bottom couple of inches off of your door and put a new outside floor/rockers in.
I used some 94x4 square tubing and welded it to the body. The trick is to prep the area real good and get a good fit. Once I had it welded to the body I took and added some that were a little heavier and welded it all together to the upper body mounts. If you don't mind some vibs then you can build a bracket that comes up from the frame. We did one like this and you'd never bend the sliders. He made the bracket so that you can unbolt it so you can pull the body if need be.
If you are REALLY concerned about bending them, use 1/4" or heavier stock. I made mine out of 1/8" x 2" x 4", and if you drop it far enough it can bend. I had fun putting them in, and it makes me feel good every rock or log I drop it on, or slam it into. I did not enjoy driving through a ditch and bending the stock rock panel flat.
Mine are made with angle iron but they wrap around the rocker panel, not built in. They have held up extremely well and seem indestructible!
Hey guys and gals. Did the same thing to my '96 sidekick sport. A stick of 2x4 tube steel 20' long cost me $100. Took it home and cut 2 pieces to the length of my rusty rotten rockers, cut out what I didn't want and welded up everything and it works great.
I dont know how the sammi compairs to the trackick, but look at these sammi slidders by Shrockworks: http://www.shrockworks.com/Suzuki-Samurai-Rock-Sliders-Rock-Rails-Rocker-Protection-pr-16143.html (http://www.shrockworks.com/Suzuki-Samurai-Rock-Sliders-Rock-Rails-Rocker-Protection-pr-16143.html)
I dont know how the sammi compairs to the trackick, but look at these sammi slidders by Shrockworks: [url]http://www.shrockworks.com/Suzuki-Samurai-Rock-Sliders-Rock-Rails-Rocker-Protection-pr-16143.html[/url] ([url]http://www.shrockworks.com/Suzuki-Samurai-Rock-Sliders-Rock-Rails-Rocker-Protection-pr-16143.html[/url])
Those are beautiful, but as far as I know there is nothing available to bolt on to a Sidekick body, just frame mount, which suck cause they hang too low.
