ZUKIWORLD Discussion Forum => Technical Discussion - Beginner / Repair => Topic started by: philc72 on October 29, 2009, 04:53:13 PM
wondering if there would be any issues with 10" wide rim on a 2002 4 door with 235 tires found a set or cheap thaqnks
235s are a little skinny on 10" rims, did they come off a low rider?
check the bolt pattern, 5.5 on 5 or is it 5 on 5.5? lol I don't remember
The rims have no tires I have 235's I wondered if they might be too skinny as well lol Need rims cheap lol
Cragar Soft 8 and V-5 aren't cheap enough at 38-40 each? If you want to add some "bling" at a later time Cragar makes polished SS rings for the lips that you press on.
thanks I will check them out
most places won't mount that size tire on the 10" rim and if they do they are taking a liability chance.
You'd be better off with a 7 or 8" rim. I run 30's on a 8" rim with a little offset and it works great. If you did manage to get them on then you'd have alot of exposed rim. I ran 10" wide on 10" rims and the rims were very beat up. To use the 10's you'd need a 12" wide tire.
I run the Swamper 33-13.5-15 LTBs on an 8" rim
My spare is a 33-12.5-15 on a 7" rim
