ZUKIWORLD Discussion Forum => Suzuki 4x4 Forum => Topic started by: roomone on November 17, 2009, 01:19:40 AM
Hello,
I'm french and just buy a X-90 after 2 Range rover classic V8.
I just want to make a soft tuning on it.
first question what tyres could i put without levelling the X-90 does 195/80/15 fits or 205/70/15??
thanks for your answers and sorry for my english...
Fred
205 was stock on many Sidekicks so that should work.
Welcome!
The X-90 has the same chassis as a Sidekick / Tracker. As you can see, the body and interior are different and the wheel well openings are smaller. There should be an information plate on your driver's side door jam that has tire information.
If you decide to perform some modifications, you can use most all the aftermarket products that are for the Sidekick / Tracker on your X-90.
Hope that helps.
welcome to the site!!!!!!!!!! Got any pics??
Before you pic. your tire size consider a min. lift. After owning the Veh.s that you mentioned a little modification might be in order. :D
